ONE show will not update with TVDB
Server Version#: 1.18.4.2171
Player Version#: iOS 6.6
Hi there,
I have one single show that refuses to match with the database. It follows the same naming convention as all my other TV shows, and I have added multiple shows since that match no problem. This particular show doesn’t grab any metadata at all. It is on the TVDB.
Naming convention of:
TV Shows>SHOW NAME (YEAR)>SEASON XX>SHOW NAME - EPISODE TITLE - SXXEYY
Hope someone can help,
Many thanks,
Naming should be:
TV Shows
  Show Name (year)
    Season XX
      Show Name (year) - sXXeYY - Optional Episode Title.ext
Where (year) isn’t mandatory but can help if there’s a reboot or other kind of same-named show.
Thanks Tom,
Thats what I have. I have the optional year Included as the show has a documentary of the same name from the 80s.
ok… in that case there had been a typo in your original post :wink:
would you mind the specific naming? I take it you already verified you’re using the same name as it is listed in TheTVDb.com?
No problem, my bad! Correct - I have verified it in TVDB. Here is the naming:
Tv Shows >
For All Mankind (2019) >
    Season 01 >
        For All Mankind (2019) - S01E01 - Red Moon.mkv
looks ok…
so Plex basically found the files but isn’t matching them / downloading metadata and artwork?
Can you manually do the match (Fix Match)?
there is no year populated for this show in tvdb, which screws up the auto matching of For All Mankind (2019)
you can either fix match (remove the 2019), or rename and remove the (2019)
I can’t see what field is missing, perhaps you have to be logged into to tvdb (I don’t have an account), but for example when comparing these 2 shows;
search no year
search with year
I can’t see any difference in visible data.
total 48064364
drwxr-xr-x. 2 chuck chuck       4096 Dec 20 23:54 ./
drwxr-xr-x. 3 chuck chuck       4096 Nov  3 04:38 ../
-rw-r--r--. 1 chuck chuck 5154655067 Nov 16 02:20 For All Mankind.S01E01.Red Moon.mkv
-rw-r--r--. 1 chuck chuck 5021374689 Nov  3 10:03 For All Mankind.S01E02.He Built the Saturn V.mkv
-rw-r--r--. 1 chuck chuck 4922463221 Nov 16 02:36 For All Mankind.S01E03.Nixon’s Women.mkv
-rw-r--r--. 1 chuck chuck 4830875362 Nov  8 07:37 For All Mankind.S01E04.Prime Crew.mkv
-rw-r--r--. 1 chuck chuck 4732996390 Nov 16 02:14 For All Mankind.S01E05.Into the Abyss.mkv
-rw-r--r--. 1 chuck chuck 4785081281 Nov 22 07:42 For All Mankind.S01E06.Home Again.mkv
-rw-r--r--. 1 chuck chuck 4855912349 Nov 28 13:36 For All Mankind.S01E07.Hi Bob.mkv
-rw-r--r--. 1 chuck chuck 4736088427 Dec  6 01:39 For All Mankind.S01E08.Rupture.mkv
-rw-r--r--. 1 chuck chuck 3980679481 Dec 13 02:13 For All Mankind.S01E09.Dangerous Liaisons.mkv
-rw-r--r--. 1 chuck chuck 6197688999 Dec 20 23:53 For All Mankind.S01E10.A City Upon a Hill.mkv
[chuck@lizum Season 02.186]$
Thank you all so much for your help. I renamed each file, rnekcinv the (2019) and adding periods at separators as per the last reply and it has finally picked it up.
Thank you again, I really appreciate it.
