Server Version#: 1.19.1
tvdb no matching, i;ve tried re-install, re-initialize, use another PC as a server.
anyone else having this issue now?
Working fine for me. Need details.
nice if we had an example as what is not working for youā¦
ok iāl try once more
This is whats happening!>>>
Logs >>> Plex Media Server Logs_2020-04-09_13-48-25.zip (9.6 MB)
ok this is getting annoyingā¦
I can see the search running in your log, but itās not getting back any results. Have you tried restarting PMS since the upgrade?
iāve reinstalled windows OS, reinstalled PMS, re-initialized. Iāve installed on another PC,
only TV shows iām having issues. this is the 2nd time i think i had issues with PMS matching with TVDB.
Z:\Plex\TV Shows\
..........Vikings (2013)\
..............Season 03\
.................S03E05 - The Usurper.mkv
Should be:
Z:\Plex\TV Shows\
................. Vikings (2013) - S03E05 - The Usurper.mkv
ā¦and technically it should be:
Z:\Plex\TV Shows\
..........Vikings\
................. Vikings - S03E05 - The Usurper.mkv
'cause thereās no (YEAR) field in the name at TVDB:
Plex and TVDB overhauled the entire matching universe recently. Proper exact naming and structuring is producing the best results:
Stray from the official Plex naming and structuring standard at your own risk.
iāve tried this already, let me try again⦠HOPEFULLY it works now.
Well, letās try something else⦠you game?
Create a New TV Show Library and New Folder for it.
All brand new.
Take a small show, remove it from the library, for safe keeping.
Scan the library
Empty the trash
Clean Bundles
Now fix the names according (precisely) to the packaged instructions for all contents therein. Check. Double Check.
Put the show in the new Library.
Letās see what happens.
which one should i follow?
this one?
*Z:\Plex\TV Shows*
*ā¦Vikings*
*ā¦Season 03*
⦠Vikings - S03E05 - The Usurper.mkv
How big is that show?
If not very, go ahead.
If you have a small show - a few episodes - that will do.
i have smaller shows⦠which naming should i follow?
TV SHOW >> Season 01 >> TV SHOW - S01E01 - EPISODE
without TV Show year??
Yes
Only add the (YEAR) field if itās in the name at TVDB.
Vikings doesnāt have a (YEAR) field.
Check TVDB for the show you use and name accordingly.
By now - you can see how easy Filebot could have made this - it went to TVDB and got the name, named all your stuff exactly that, and had it in your Plexiverse a week ago:
no joy, still the same⦠iāll wait for it⦠iāll reply in a few hours
Do this while we wait:
done that.
Show us your file names.
How 'bout a screenshot?
Prepare a new set of logs.
Doesnāt match when i try āFix Matchā. following the TVDB names
