I reply myself by saying that I changed my HDMI cable and do a new installation on another SD card. I have no problem since then. I hope he stays like that.
I’ve just finished setting up my newly arrived Odroid C2. Everything is just working!!!
Just one question: I’ve read something about not turning it off, because it will need very little power in idle… so OpenPHT is only in the menu for some minutes, nothing is being played or anything, but it definitely gets warm and stays that way (inserted in the official Odroid case). Am I doing anything wrong or is it fine?
Does anyone else experience periodic audio/video sync issues? There’s occasionally a lag of a what seems like a few milliseconds, just enough to make it noticeable and annoying. It seems to be more prevalent with HEVC/x265 content but I’m not sure. It’s not present on all content otherwise I’d use the audio delay feature to correct it, nor does the lag seem consistent even within the same movie. Some scenes are in perfect sync and a few scenes later it’s not, then a few scenes later it’s back in sync. Almost all of my content uses DTS or Dolby lossless audio ripped straight from the Blu-ray at 1080p.
I’m streaming this over a gigabit network so it’s not a bandwidth issue. My Plex server is a Dell R710 with twelve 3Ghz cores feeding from a 12 drive SAS RAID array so that’s not causing it. I suspect the ODroid C2 might be having a hard time doing the real-time decode of HEVC/x265 while keeping it in sync with the audio. Any thoughts?
Im having issues with VC-1 content, even though I’ve read on this thread its either fixed, or only happens with interlaced VC-1. For me, it’s happening on any VC-1 content. Some videos it’s very bad, on others its just slightly choppy.
Here’s some info on both types of outcomes.
Format : Matroska
Format version : Version 2
File size : 16.2 GiB
Duration : 2 h 20 min
Overall bit rate mode : Variable
Overall bit rate : 16.6 Mb/s
Encoded date : UTC 2016-03-05 23:29:29
Writing application : MakeMKV v1.9.9 win(x64-release)
Writing library : libmakemkv v1.9.9 (1.3.3/1.4.4) win(x64-release)
Original source medium : Blu-ray
Video
ID in the original source medium : 4113 (0x1011)
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Bit rate : 13.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.275
Stream size : 13.4 GiB (83%)
Language : English
Default : No
Forced : No
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Delay relative to video : 83 ms
Stream size : 641 MiB (4%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Format : Matroska
File size : 16.1 GiB
Duration : 1 h 13 min
Overall bit rate : 31.5 Mb/s
Movie name : Band of Brothers Disc 1
Encoded date : UTC 2017-05-09 04:01:06
Writing application : MakeMKV v1.10.4 win(x64-release)
Writing library : libmakemkv v1.10.4 (1.3.3/1.4.4) win(x64-release)
Video
Format : VC-1
Bit rate : 27.7 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.558
Stream size : 14.2 GiB (88%)
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : 2 166 kb/s / 1 509 kb/s
Frame rate : 93.750 FPS (512 spf)
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Stream size : 1.11 GiB (7%)
Language : English
Default : Yes
Forced : No
I reported the same issue on January 28. None of my VC-1 bluray’s ripped in MKV will play smoothly:
"I just set up a C2 with embedded OpenPHT on an eMMC card. Scrolling my 500 bluray rip library is much faster and smoother than on my Rpi2. HD audio passthrough works great.
However… my VC-1 bluray rips do not play smoothly with or without hardware acceleration. You can see Benjamin’s response to my post about 16 posts up. It is a known issue, and won’t be fixed until OpenPHT v2. (MAYBE)
I tried every combination of video/audio setting on the eMMC card and 2 SD cards and no joy on VC-1. Since I probably have at least 60-80 VC-1 movies, I wont’ be using this C2 until OpenPHT v2 is out.
I did find a beta Libre elec Kodi image that played VC-1 properly, but I don’t want to use Kodi, even with the Plex addon.
I’m not sure why most people don’t seem to be having this issue with VC-1 also?"
So my Odroid C2 has been sitting in a drawer for the last 6 months waiting for possible fix
I’m having issues with my wifi disconnecting when idle on my odroid c2. I’m using the ODROID WIFI MODULE 5 as my wifi adapter. Anyone having this problem and know how to fix it? I’ve tried a clean install and still the same issue occurs. Running on a EMMC module on OpenPHT-Embedded-1.8.0.148-573b6d73-Odroid_C2.aarch64.img
Thats a huge bummer. I may have to shelve the Odroid for now as well, unfortunately
Yes that’s correct, it’s not built in. I’m using the USB adaptor that is recommended by hardkernel. CSR8510 Bluetooth module 2.
I’m only getting connection problems on OpenPHT version 1.8.0 and 1.7.1 but strangely it works on version 1.6.2
So the new odroid-c2 arrived, flashed the rpi sd card with the odroid build and booted up.. CEC is working like the rpi with my Sony TV remote.
The UI is sooo much smoother, i tested some videos from my local plex library and everything was direct-playing with minimal cpu usage, very satisfied.
I tried some test files to check what the odroid is really capable of, so i downloaded those from http://jell.yfish.us/:
At first videos played fine on my oDroid c2 but now after a couple days I’m having an issue where I select a video to play and the screen goes black for a bit and after a while it will eventually begin to play with a message in the corner that says “cache filled before reaching required amount…” (it gets cut off). Any ideas how to solve this cache issue?
