Over the air channels stopped working in September of 2024
There’s Plex Media Server - #666 by gbooker02 v. 1.41.5.9522 available now. Is all this behind us? Anyone? @Atomatth ? Bueller?
I still have an open issue linked to this thread. So I’d say, no. I have been able to reproduce the issue.
[h264_qsv @ 000001ef625a82c0] Error during encoding: device failed (-17)
This usually results in a Weak Signal error message
It’s looking like the resolution is going to be a bit involved and requiring major updates on PMS. Thankfully this work was already scheduled but unfortunately will take some time.
My understanding of the issue is that it’s limited to Windows hosts with older CPU/iGPU. So far Roku is the client where this has been confirmed. I have seen others chime in mentioning other clients but without logs :person_shrugging:.
So for anyone tracking this thread or jumping in late, if you think this issue matches what you’re seeing please share your PMS logs. Please also call out any affected clients.
Thanks for the bump @tchaugland
2 posts were split to a new topic: Recording failed. Please check your tuner or antenna
Springtime is a busy time for me; apologies for the late reply on my part.
Thank you for your reply @Atomatth … as an update, I still very occassionally get the playback error. However, it has become few and far between, so I feel it’s merely an annoyance. No big deal. Luckily, I haven’t seen the issue while recording, only while watching live.
For now I can live with it. But I’ll also keep an eye here & look forward to the resolution.
Thanks again…
Bumping to keep this alive. I haven’t been able to update my Plex server since September 2024 because of this issue. Any status updates about this are greatly appreciated. Thanks.
Greetings All,
I last posted on November of 2024. Recently, I clicked on the “Download Updates Screen” in Settings/General, PMS was upgraded to v.1.42.1.10060-4e8b05daf of August 11, 2025.
I am running Windows 11, with all current updates.
After the update to v.1.42.1.10060-4e8b05daf my Recorded TV Shows began to not record the show completely. Some partially (About 1/2 the show) and others only the first 4 to 10 seconds or so. I have uploaded the the Logs from Troubleshooting for review.
I thought I would wait to see if the issue was resolved.
Please let me know if other information is required.
Plex Media Server Logs_2025-09-02_14-57-35.zip (4.4 MB)
It’s been a while since I posted on this thread but live TV is still not working reliably for me. In my case, that’s true for IOS (iPad) or Android. The error messages vary depending on whether I have HW transcoding enabled. When I turned off HW transcoding, live TV played for a few minutes then stopped with a “The requested URL was not found on this server” message. With HW encoding enabled, I get a long error after a few minutes that ends with “unable to get playlist before long download timer.”
I’m using PMS Version 1.42.1.10060
Edition Windows 11 Pro
Version 24H2
Installed on ‎10/‎14/‎2024
OS build 26100.5074
Experience Windows Feature Experience Pack 1000.26100.234.0
Attached are the logs collected just after the most recent error. Any help is greatly appreciated.
Plex Media Server Logs_2025-09-05_16-21-42.zip (541.5 KB)
Interesting update. The stream that fails is the 1080 resolutions transcoded via HW.
In the screenshot above, the two lower resolution streams, (480i and 720p) have been streaming fine for a half hour+. The 1080i stream going to iOS will only go for a couple minutes before returning the error “The operation couldn’t be completed (CoreMediaErrorDomain error-16839 - Unable to get playlist before long download timer.)
Update 2: It’s not the resolution. A 480i stream on iOS just failed with the same error. Now it appears to be an iOS client issue when HW transcoding is enabled.
Your system is pretty FUBAR’d.
Ran Plex as a Service but you probably used different users mixing permissions.
Database is having problems. (GitHub - ChuckPa/DBRepair: Database repair utility for Plex Media Server databases) may fix the physical but if their are logical problems then restore a backup.
Improper values in “Allowed Networks”
Probably have a codecs problems.
Might want to ditch the pseudo HDHomerun tuners.
Aug 10, 2025 11:58:27.625 [57632] ERROR - Error parsing allowedNetworks entry ' 100.64.75.116': An invalid argument was supplied [system:10022]
Aug 10, 2025 11:58:27.625 [57632] ERROR - Error parsing allowedNetworks entry ' 100.110.23.39': An invalid argument was supplied [system:10022]
Aug 10, 2025 11:58:27.625 [57632] ERROR - Error parsing allowedNetworks entry ' 100.90.153.66': An invalid argument was supplied [system:10022]
Aug 10, 2025 11:58:27.625 [57632] ERROR - Error parsing allowedNetworks entry ' 100.110.46.86': An invalid argument was supplied [system:10022]
Aug 10, 2025 11:58:27.930 [60708] INFO - SQLITE3:(nil), 283, recovered 450 frames from WAL file D:\Plex\Plex Media Server\Plug-in Support\Databases\tv.plex.providers.epg.cloud-5b31d672-1cfe-4ce3-846f-9e82177b33ad.db-wal
Aug 10, 2025 11:58:27.935 [69816] INFO - Refreshing paths watched by LibraryUpdateManager
Aug 10, 2025 11:58:27.939 [60708] INFO - Running migrations. (EPG 1)
Aug 10, 2025 11:58:29.145 [66736] WARN - [EventSourceClient/pubsub/172.104.24.90:443] MyPlex: attempted a reachability check but we're not yet mapped.
Aug 10, 2025 11:58:39.465 [69804] WARN - [HttpClient/HCl#27] HTTP error requesting GET http://localhost:6077/discover.json (7, Couldn't connect to server) (Failed to connect to localhost port 6077 after 2254 ms: Couldn't connect to server)
Aug 10, 2025 11:58:39.465 [70460] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1052D382, marking as dead.
Aug 10, 2025 11:58:41.538 [69804] WARN - [HttpClient/HCl#2e] HTTP error requesting GET http://127.0.0.1:34400/discover.json (7, Couldn't connect to server) (Failed to connect to 127.0.0.1 port 34400 after 2021 ms: Couldn't connect to server)
Aug 10, 2025 11:58:41.539 [70460] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2025-01-69WD-TBX9RZ, marking as dead.
Aug 10, 2025 11:58:43.580 [69804] WARN - [HttpClient/HCl#31] HTTP error requesting GET http://192.168.50.15:34400/discover.json (7, Couldn't connect to server) (Failed to connect to 192.168.50.15 port 34400 after 2041 ms: Couldn't connect to server)
Aug 10, 2025 11:58:43.581 [70460] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2025-01-6IE0-NLHJI8:2, marking as dead.
Aug 10, 2025 11:58:48.354 [69804] WARN - [HttpClient/HCl#37] HTTP error requesting GET http://localhost:6077/discover.json (7, Couldn't connect to server) (Failed to connect to localhost port 6077 after 2248 ms: Couldn't connect to server)
Aug 10, 2025 11:58:48.354 [67532] ERROR - [NSB/SSDP] DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1052D382, marking as dead.
Aug 10, 2025 11:58:50.392 [69804] WARN - [HttpClient/HCl#38] HTTP error requesting GET http://127.0.0.1:34400/discover.json (7, Couldn't connect to server) (Failed to connect to 127.0.0.1 port 34400 after 2038 ms: Couldn't connect to server)
Aug 10, 2025 11:58:50.393 [67532] ERROR - [NSB/SSDP] DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2025-01-69WD-TBX9RZ, marking as dead.
Aug 10, 2025 11:58:52.429 [69804] WARN - [HttpClient/HCl#39] HTTP error requesting GET http://192.168.50.15:34400/discover.json (7, Couldn't connect to server) (Failed to connect to 192.168.50.15 port 34400 after 2035 ms: Couldn't connect to server)
Aug 10, 2025 11:58:52.430 [67532] ERROR - [NSB/SSDP] DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2025-01-6IE0-NLHJI8:2, marking as dead.
I see others are still having this issue, as I still am. I have major problems with just one channel, which I think is the tower. I do have fewer frequent issues on many other channels, though. So I think whatever is happening is still a ‘bug.’ @pl_5309 - what do you mean by pseudo HDHomerun tuners?
Since their are so many posters I should of tagged the response with @rodhess.
