Part of a series missing first 10 episodes
Hi Folks,
As per title, I got a copy of Death note and although all 37 episodes are on disc, plex can only see 10->37, what am I missing???
Screensots attached.
Server Version#: 1.15.6.1079
Player Version#: Effects all players
Your file names are not correct.
  1. Look up your show on TheTVDB
  2. Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like § : % *, simply leave them out.
  3. Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases. Add the (year) in parentheses of when episode 1 of season 1 of this show was aired.
  4. Name the episode files according to the above linked naming guide. Use the same title as for the top folder. Show's Title (year) - s01e01 - additional info.ext (’- additional info’ can be left out)
  5. After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
Thanks I’ll try that.
