Partial Metadata missing from TV Show
Server Version#:1.41.4.9463
Player Version#:1.108.1.307-dd5b87aa
Need some advice on how to tweak the settings to fix this. I have recently added a 2nd Season of a show called Dodo (Dodo: Season 2 — The Movie Database (TMDB)) to my plex server. I’m using the modern series scanner/scraper combo and TheTVDB ordering. For some reason it’s providing metadata for the first 4 episodes only and the rest have no metadata. I understand the modern scraper uses various information sources to give the richest information available but for whatever reason the data appears to be missing for the remaining episodes. As I’m not 100% certain which service the data is scraped from I can’t go there to independently verify it. Before I go the route of adding the data locally thought it was worth asking if there is a way to troubleshoot this or is it just a case of waiting for the remote data source to be fixed?
thanks.
Try switching that series to TMDB ordering. As far as I can see, TVDB and TMDB have the same data for this one.
that fixed it. thank you.
