Server Version#: 1.19.4.2935 on FreeBSD 12.1
Player Version#: Plex Web Version 4.37.2
Kaby Lake CPU (E3-1225v6) with hw transcode enabled.
Movies with PGS or vobsub subtitles will fail to play. Player will just “sit there”, logs from starting, waiting for a bit and then cancelling below.
Switching hw transcode off resolves the issue.
I’m assuming the answer is “Intel needs to fix iHD”, and, it’s always good to verify.
Software transcode works and is adequate for what I’m doing.
Transcoder Statistics Log:
<Variants>
<Variant id="2da9fa81-02f0-45c1-97c1-b812c741aedc" targetBitrate="26948" context="streaming" sourceVideoCodec="h264" sourceAudioCodec="dca" videoDecision="transcode" audioDecision="transcode" subtitleDecision="burn" protocol="dash" container="mp4" videoCodec="h264" audioCodec="aac" audioChannels="2" transcodeHwRequested="1" transcodeHwDecoding="vaapi" transcodeHwEncoding="vaapi" transcodeHwDecodingTitle="Intel (VA API)" transcodeHwEncodingTitle="Intel (VA API)" transcodeHwFullPipeline="0">
<Media audioProfile="ma" id="7362" videoProfile="high" audioChannels="2" audioCodec="aac" bitrate="25664" container="mp4" duration="7333331" height="1080" optimizedForStreaming="1" protocol="dash" videoCodec="h264" videoFrameRate="24p" videoResolution="1080p" width="1920" selected="1">
<Part audioProfile="ma" deepAnalysisVersion="4" id="7547" indexes="sd" requiredBandwidths="33909,32325,30288,28041,27146,26525,23498,21773" videoProfile="high" bitrate="25664" container="mp4" duration="7333331" height="1080" optimizedForStreaming="1" protocol="dash" width="1920" decision="transcode" selected="1">
<Stream bitrate="25408" chromaLocation="left" codec="h264" colorPrimaries="bt709" colorTrc="bt709" displayTitle="1080p (H.264)" frameRate="23.975999999999999" height="1080" id="10792" language="English" languageCode="eng" requiredBandwidths="31114,29408,27432,25213,24420,23786,20772,19253" streamType="1" width="1920" decision="transcode" location="segments-video" />
<Stream bitrate="256" bitrateMode="cbr" channels="2" codec="aac" default="1" displayTitle="한국어 (DTS-HD MA 5.1)" id="10793" language="한국어" languageCode="kor" requiredBandwidths="2655,2565,2446,2446,2446,2446,2446,2446" selected="1" streamType="2" decision="transcode" location="segments-audio" />
<Stream burn="1" default="1" displayTitle="English (PGS)" id="10794" language="English" languageCode="eng" requiredBandwidths="30,30,30,30,30,30,30,30" selected="1" streamType="3" decision="burn" location="segments-video" />
</Part>
</Media>
</Variant>
</Variants>
<SegmentList>
<Segment duration="0" startOffset="-1" endOffset="-1">
<Timelines>
<Download startTime="116" fileType="audio" variant="2da9fa81-02f0-45c1-97c1-b812c741aedc" />
<Download startTime="117" fileType="video" variant="2da9fa81-02f0-45c1-97c1-b812c741aedc" />
<Download startTime="127749" fileType="video" variant="2da9fa81-02f0-45c1-97c1-b812c741aedc" />
<Download startTime="128143" fileType="audio" variant="2da9fa81-02f0-45c1-97c1-b812c741aedc" />
</Timelines>
</Segment>
</SegmentList>
<PlaybackReports>
<Playback startTime="157412" endTime="158437" state="paused" progress="3300000" />
<Playback startTime="158437" endTime="162728" state="playing" progress="3300000" />
<Playback startTime="162728" state="stopped" progress="3300000" />
</PlaybackReports>
<StateReports />
<StateReports />
</SessionReport>
Plex Media Server log:
Jul 10, 2020 13:57:13.940 [0x80c2c8f00] WARN - [FFMPEG] - No quality level set; using default (20).
Jul 10, 2020 13:58:04.077 [0x80c20e400] WARN - Deleted file "/tmp/logs.zip1308326b-abd5-4c3b-a5b3-69212a549cfa" after connection reset
Jul 10, 2020 13:59:20.962 [0x81724d700] WARN - Timed out waiting for segment.
Jul 10, 2020 13:59:21.070 [0x81658d600] WARN - Timed out waiting for segment.
Jul 10, 2020 13:59:56.813 [0x817226200] ERROR - Unknown metadata type: folder
Jul 10, 2020 13:59:56.878 [0x816422f00] WARN - Transcode runner appears to have died.
Jul 10, 2020 13:59:56.878 [0x81658b800] WARN - Transcode runner appears to have died.
Jul 10, 2020 13:59:59.222 [0x816425700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jul 10, 2020 13:59:59.242 [0x816425700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jul 10, 2020 13:59:59.251 [0x816425700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jul 10, 2020 14:00:02.243 [0x816ffa400] ERROR - Unknown metadata type: folder
Jul 10, 2020 14:00:29.378 [0x81724be00] ERROR - Unknown metadata type: folder
