Pinned unavailable libraries duplicated…
Can someone help me with this?
These libraries with the yellow triangle just randomly appeared in Plex on my Apple TV.
What is the cause of it and how do I remove them all?
There’s like 50-60 it just keeps repeating.
I am having the exact same problem all the sudden. I have to click the three-dots next to home, and reset to defaults to clear them all out and go back to normal. But it just keeps adding them when I close and re-open the app. Also, they only show up on Apple TV, not on the web interface, and they only seem to show up in my kids ‘managed account’, not in the primary un-managed account.
i have been doing that, resetting the the defaults, nobody else seems to have the issue, also it the same for me on my apple tv, nowhere else does it happen.
Do you have old servers listed at https://app.plex.tv/desktop/#!/settings/devices/pms
No, for me - it only shows the 1, active server which is a Linux Server (Linux 22.04.1 LTS (Jammy Jellyfish)
is it possible to get the apple tv logs. you can message them to me
Thanks for the follow-up. I tried exporting/downloading the logs, but I don’t see any in the .zip file mentioning Apple-TV. I guess I’m not really sure where the Apple-TV logfile is located. I did a quick search on the forums, and couldn’t find it (though certainly may have missed it). Thx.
I couldn’t get to the root cause of what was causing this for only the one user. So I decided to create a new user for my kids instead. That seems to be working fine now. I just removed the old user, and they use that new user now without this bug appearing.
