Recently I have been getting this error when I try to play some of my movie files. This is odd coz they used to play fine before.
Server Version#: 1.22.1.4228-6000 (Synology DS1621+ ; DSM: 6.2.3-25426 Update 3)
Player Version#: via Samsung SmartTV Tizen OS - Client ver# 5.11.2 ; Platform ver#2.4 Plex Media Server Logs_2021-03-31_17-46-32.zip (3.8 MB)
Same issue here. I even restarted the docker container and still nothing. I am able to watch movies if i play directly from the Web GUI from the local IP Address. But the moment I do a remote stream it fails.
Ditto. I canāt start a movie from the web GUI. Iām greeted with this error message. Iām running the just dropped. PlexMediaServer 1.22.2.4264-b275c4330-x86_64_DSM6 install.
I also have this problem, and found errors in the browserās console. The attached log files are rips of the server and console logs when the error occurs.
This is on ubuntu server 20.04.1 LTS in a virtual machine under proxmox, and it is not using hardware transcoding. ErrorBrowserConsoleLogRip.txt (100.3 KB) ErrorServerLogRip.txt (16.0 KB)
I just started to have this issue today. Last night everything was fine and today I have been getting the error across all devices.Plex Media Server Logs_2021-03-31_19-16-10.zip (4.4 MB)
Update: The issue appears to be unique to app.plex.tv in some way.
1: We found an error saying beignet-opencl-icd needed to be installed, and installed that.
2: We found that the local-network URL worked, i.e. http://10.10.100.2:32400/web/index.html
Iād suggest you go to Settings > Network > Preferred network interface and select the interface enp5s0
Also Settings > Transcoder > and UncheckDisable video stream transcoding
Another thing, it seems your hardware transcoding isnāt working because you keep getting the error below: DEBUG - [Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Generic error in an external library
But thatās a subject for another topic.
After following the steps above, do you still get the error?
You were able to direct play ā2 Fast 2 Furious (2003)ā and āThe Santa Clause 2 (2002)ā but Batman.v.Superman.Dawn.of.Justice.2016 shows the error
WARN - [Transcode] Denying access due to session lacking permission to transcode key /library/metadata/61
Did you change anything related to permissions?
Also go to Settings > Transcoder > and UncheckDisable video stream transcoding
Those are both in the correct position. The thing is, it works fine on mobile and roku apps. Just not on the web app. Seems to be a problem for a lot of people too. Also it just started happening. Iāve been transcoding and using plex for months without an issue.
I am not sure how to do this? I can only select āAnyā or "bond0(192.168.1.xx) - I selected bond0
With this I manage to get some of my videos working but now I get another error.
Playback Error - Conversion failed. The transcoder failed to start up.
So I have been following along with the various suggestions and still am having the issue. I was able to get some shows to play but others still give the error. I disabled the subtitles for the TV show episode that had issues. No effect. Tried to take a look to change the āfolderā for transcoding and am not able to see what is being talked about.
