Something going on with the network.
It keeps resetting.
May 28, 2025 20:48:23.644 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:23.667 [23308736678712] DEBUG - Codecs: dummy-frame test succeeded
May 28, 2025 20:48:23.949 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1432, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.949 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=26, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:23.949 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:23.949 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:23.954 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:23.954 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1432, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.954 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=27, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:23.954 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:23.954 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1756, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=27, flags=0x1002, change=0x0
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:23.955 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=27, flags=0x1002, change=0x100
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=27, flags=0x1002, change=0x0
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1756, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.956 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=27, flags=0x1003, change=0x1
May 28, 2025 20:48:23.957 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:23.957 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:23.957 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=27, flags=0x1003, change=0x0
May 28, 2025 20:48:23.957 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:23.957 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:23.958 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:24.033 [23308736678712] DEBUG - Clipped max bitrate to 1328Kbps based on client-requested limit
May 28, 2025 20:48:24.033 [23308736678712] DEBUG - MDE: Selected protocol http; container: mkv
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: analyzing media item 187476
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Direct Play is disabled
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/truehd
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): non-selected embedded subtitle stream 657900 cannot be direct-played
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): non-selected embedded subtitle stream 657901 cannot be direct-played
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/dca
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/ac3
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - The Beekeeper - video.width limitation applies: 3840 > 720
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - The Beekeeper - audio.channels limitation applies: 8 > 2
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Direct Streaming is disabled, so video stream will be transcoded
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no remuxable profile found, so video stream will be transcoded
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - Codecs: testing h264_nvenc (encoder)
May 28, 2025 20:48:24.034 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:24.165 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=648, type=RTM_DELLINK, flags=0x0
May 28, 2025 20:48:24.165 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=26, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:24.168 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:24.184 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:24.184 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=27, flags=0x11043, change=0x0
May 28, 2025 20:48:24.184 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:24.184 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:24.185 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:24.185 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:24.185 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=27, flags=0x11043, change=0x0
May 28, 2025 20:48:24.185 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:24.185 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:24.186 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:24.186 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1764, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:24.186 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=27, flags=0x11043, change=0x0
May 28, 2025 20:48:24.186 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:24.186 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:24.521 [23308736678712] DEBUG - Codecs: testing hevc_nvenc (encoder)
May 28, 2025 20:48:24.521 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:24.649 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:25.002 [23308736678712] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 28, 2025 20:48:25.003 [23308736678712] DEBUG - Codecs: testing hevc (decoder) with hwdevice nvdec
May 28, 2025 20:48:25.003 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvdec for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - Codecs: Testing with profile 'Main 10'
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 20(IDR_N_LP), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Decoding VPS
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Main 10 profile bitstream
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Decoding SPS
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Decoding VUI
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Decoding PPS
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Format cuda chosen by get_format().
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - Format cuda requires hwaccel initialisation.
May 28, 2025 20:48:25.166 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:25.188 [23308736678712] DEBUG - Codecs: dummy-frame test succeeded
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - Clipped max bitrate to 1328Kbps based on client-requested limit
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - MDE: The Beekeeper (2024): selected media 0 / 187476
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - Streaming Resource: Reducing playback quality for 1429kbps stream bitrate: quality to 48, disable video DS as 111852kbps is > the 1245kbps available
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - Codecs: testing h264_nvenc (encoder)
May 28, 2025 20:48:25.525 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:25.654 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:26.007 [23308736678712] DEBUG - Codecs: testing hevc_nvenc (encoder)
May 28, 2025 20:48:26.007 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:26.144 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:26.498 [23308736678712] DEBUG - Codecs: testing hevc (decoder) with hwdevice nvdec
May 28, 2025 20:48:26.499 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvdec for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - Codecs: Testing with profile 'Main 10'
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 20(IDR_N_LP), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Decoding VPS
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Main 10 profile bitstream
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Decoding SPS
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Decoding VUI
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Decoding PPS
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Format cuda chosen by get_format().
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - Format cuda requires hwaccel initialisation.
May 28, 2025 20:48:26.627 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:26.628 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:26.651 [23308736678712] DEBUG - Codecs: dummy-frame test succeeded
May 28, 2025 20:48:26.988 [23308736678712] DEBUG - Clipped max bitrate to 1245Kbps based on client-requested limit
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: Selected protocol http; container: mkv
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: analyzing media item 187476
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Direct Play is disabled
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/truehd
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): non-selected embedded subtitle stream 657900 cannot be direct-played
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): non-selected embedded subtitle stream 657901 cannot be direct-played
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/dca
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no direct play video profile exists for http/mkv/hevc/ac3
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - The Beekeeper - video.width limitation applies: 3840 > 720
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - The Beekeeper - audio.channels limitation applies: 8 > 2
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Direct Streaming is disabled, so video stream will be transcoded
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - MDE: The Beekeeper (2024): no remuxable profile found, so video stream will be transcoded
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - Codecs: testing h264_nvenc (encoder)
May 28, 2025 20:48:26.989 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:27.121 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:27.477 [23308736678712] DEBUG - Codecs: testing hevc_nvenc (encoder)
May 28, 2025 20:48:27.477 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:27.605 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:27.959 [23308736678712] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 28, 2025 20:48:27.959 [23308736678712] DEBUG - Codecs: testing hevc (decoder) with hwdevice nvdec
May 28, 2025 20:48:27.959 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvdec for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - Codecs: Testing with profile 'Main 10'
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 20(IDR_N_LP), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Decoding VPS
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Main 10 profile bitstream
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Decoding SPS
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Decoding VUI
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Decoding PPS
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Format cuda chosen by get_format().
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - Format cuda requires hwaccel initialisation.
May 28, 2025 20:48:28.088 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:28.108 [23308736678712] DEBUG - Codecs: dummy-frame test succeeded
May 28, 2025 20:48:28.468 [23308736678712] DEBUG - Clipped max bitrate to 1245Kbps based on client-requested limit
May 28, 2025 20:48:28.468 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - MDE: The Beekeeper (2024): selected media 0 / 187476
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - Streaming Resource: Reducing playback quality for 1334kbps stream bitrate: quality to 42, disable video DS as 111852kbps is > the 1163kbps available
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - Codecs: testing h264_nvenc (encoder)
May 28, 2025 20:48:28.469 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:28.606 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:28.959 [23308736678712] DEBUG - Codecs: testing hevc_nvenc (encoder)
May 28, 2025 20:48:28.959 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvenc for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:29.096 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:29.300 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1432, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.300 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=28, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:29.300 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.300 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1432, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=29, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1756, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.305 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=29, flags=0x1002, change=0x0
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1756, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=29, flags=0x1002, change=0x100
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.306 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=29, flags=0x1002, change=0x0
May 28, 2025 20:48:29.307 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.307 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1756, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.307 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=29, flags=0x1003, change=0x1
May 28, 2025 20:48:29.307 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.307 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.308 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.308 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.308 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=29, flags=0x1003, change=0x0
May 28, 2025 20:48:29.308 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.308 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.453 [23308736678712] DEBUG - Codecs: testing hevc (decoder) with hwdevice nvdec
May 28, 2025 20:48:29.453 [23308736678712] DEBUG - Codecs: hardware transcoding: testing API nvdec for device 'pci:0000:29:00.0' (NVIDIA TU116 [GeForce GTX 1660])
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - Codecs: Testing with profile 'Main 10'
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - nal_unit_type: 20(IDR_N_LP), nuh_layer_id: 0, temporal_id: 0
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Decoding VPS
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Main 10 profile bitstream
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Decoding SPS
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Decoding VUI
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Decoding PPS
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Format cuda chosen by get_format().
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - Format cuda requires hwaccel initialisation.
May 28, 2025 20:48:29.605 [23308736678712] DEBUG - [FFMPEG] - CUDA texture alignment: 512
May 28, 2025 20:48:29.606 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=648, type=RTM_DELLINK, flags=0x0
May 28, 2025 20:48:29.606 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=28, flags=0x1002, change=0xffffffff
May 28, 2025 20:48:29.623 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.623 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=29, flags=0x11043, change=0x0
May 28, 2025 20:48:29.623 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.623 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.624 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.624 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=408, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.624 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=7, type=1, index=29, flags=0x11043, change=0x0
May 28, 2025 20:48:29.624 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.624 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.625 [23308548512568] DEBUG - Network change notification but nothing changed.
May 28, 2025 20:48:29.625 [23308548512568] DEBUG - NetworkInterface: received Netlink message len=1764, type=RTM_NEWLINK, flags=0x0
May 28, 2025 20:48:29.625 [23308548512568] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=29, flags=0x11043, change=0x0
May 28, 2025 20:48:29.625 [23308548512568] DEBUG - Network change.
May 28, 2025 20:48:29.625 [23308548512568] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 28, 2025 20:48:29.625 [23308736678712] DEBUG - Codecs: dummy-frame test succeeded
May 28, 2025 20:48:29.964 [23308736678712] DEBUG - Clipped max bitrate to 1163Kbps based on client-requested limit
May 28, 2025 20:48:29.964 [23308736678712] DEBUG - MDE: Selected protocol http; container: mkv
May 28, 2025 20:48:29.964 [23308736678712] DEBUG - MDE: analyzing media item 187476
May 28, 2025 20:48:29.964 [23308736678712] DEBUG - MDE: The Beekeeper (2024): Direct Play is disabled
Is br0 on a DHCP address or static?
Is br0’s physical adapter wired or wifi ?
If DHCP, check the lease time
If WiFi, verify it’s not falling out of the SSID. (servers are best wired)
