The web app has worked splendidly ever for several months, but ever since this Friday, when my web app got some sort of update (the GUI changed over night for me), my videos keep on interrupting. It’s the same error code. Please tell me what this code means, and if it’s something I can fix!
Plex Media Server: macOS Sierra
Plex App: Safari on same macOS Sierra
Hi I have been receiving a similar error too “shaka3016(Media)”
Does it happen with every video or just particular videos? If specific videos, a sample we could use to reproduce the error would help a lot.
For me, it has happened since the new update as well. It has happened with every video I have watched. All of which have been quite large videos about 44 mins long and about 4GB in size.
Does it happen in the middle of playback or at the start? If in the middle, does it happen at approximately the same time into the video?
It has happened within the last 3 minutes everytime without fail.
What version of Plex Media Server are you running?
Could you restart your server, reproduce the error, and provide Plex Media Server logs?
I am running the most recent as of today: Version 1.7.5.403
My server has restarted multiple times in between the errors.
I’ve just tested the videos outside of plex and they all play through fine using any other media player. Additionally, if I change the viewing settings to be anything other than “Original” the errors cease.
UPDATE 9/7/17: I’m still experiencing this on 1.8.3.4235.
Another user here with the same experience.
I haven’t thumbed through the rest of my catalog to see where else this is happening, but I am able to reproduce the error with a particular video. It’s Ed Sheeran’s 2014 iTunes Festival performance. I’ve made the file available through my OneDrive so you can do some testing with it. Apologies for the high bitrate / filesize (~6.4GB).
I’ve played the file in question back successfully many times in the past using PLEX without issue. File plays fine through Windows Media Player.
Haven’t been able to get it to happen starting right from the beginning of playback. One thing I’ve noticed is that it’s always related to me skipping to random points in the video file. Interestingly, small skips (one or two minutes) don’t seem to reproduce the error, only large skips (25%+ of the video’s total length). If I do small skips to get to the timecode marker where a large skip crapped out, it will normally play through that section just fine. Occasionally I can jump from the start of a video to almost the end without any problems. But then if I jump back in the video I’ll get the error. Normally only takes 3-4 big jumps before I get the error.
I’m running 1.7.5.4035.
Environment Notes
Host machine is Windows 10 machine running an Ubuntu VM that hosts PLEX. Playback was done with Chrome on my main desktop environment by connecting to PLEX via the network (via plex.tv). The media files are accessed by PLEX through a mounted folder share that connects to a local storage array on the machine running the PLEX VM. Virtualization is done by VMWare Workstation 12.5.7 build-5813279. About 26GB free on the disk. VM has 6GB of ram and 4 cores dedicated to it.
I received the same error. Here is information on the situation:
Host: Windows Server 2016, PMS 1.8.0.4109, file storage on SMB Share
Client: PlexWEB CHrome 60.0.3112.90 х64
**File: **
Time: 3:27:39
Size 610.71 MB
Container MKV
Video Profile main
Codec H264
Same issue. Only had the issue since I started watching a new series. 60 minute length H.264 MKV, around 11000 kbps, 24fps, 1080p. Had the issue intermittently with all episodes of both seasons I have. The first 5-6 times it happened in the last 3 minutes or so, conveniently always within a few seconds of the credits rolling. Not sure if this is coincidence or not. The time that spurred me to write this is that it started happening in the opening theme now.
Ubuntu Server 16.0.4.2
Plex Media Server 1.7.5.4035
Streamed remotely to Chrome 60.0.3112.90 on Windows 10
Video direct stream
Audio transcoded EAC3 5.1 to AAC
debian server buster/sid
Plex media server 1.8.1.4139
Streamed remotly to chrome/IE/Edge on windows 10 (all these browsers give same error, firefox works)
I am trying to play back music (mp3 files)
if I check the chrome://media-internals I get this info:
I’m getting this as well on files I know have previously played fine. The only thing I see in my plexmediaserver.log is…
Aug 24, 2017 10:16:33.228 [0x7f850cffe700] ERROR - get - invalid frameRate value: 23.976
Aug 24, 2017 10:16:35.109 [0x7f850d7ff700] ERROR - [Transcoder] [dash @ 0x1e21f40] Cannot use rename on non file protocol, this may lead to races and temporary partial files
Aug 24, 2017 10:16:35.392 [0x7f8519ddf700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 236520 is out of range for mov/mp4 format
Aug 24, 2017 10:16:36.311 [0x7f850cffe700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 724952 is out of range for mov/mp4 format
Aug 24, 2017 10:16:37.255 [0x7f850cffe700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 1447896 is out of range for mov/mp4 format
Aug 24, 2017 10:16:39.151 [0x7f8518fff700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 3120104 is out of range for mov/mp4 format
Aug 24, 2017 10:16:41.257 [0x7f8518fff700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 4589544 is out of range for mov/mp4 format
Aug 24, 2017 10:16:47.495 [0x7f8519ddf700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 9377768 is out of range for mov/mp4 format
Aug 24, 2017 10:16:52.202 [0x7f85113ff700] ERROR - [Transcoder] [mp4 @ 0x1efa800] Application provided duration: -16 / timestamp: 12991448 is out of range for mov/mp4 format
I just started receiving the same error today. (shaka3015) I also noticed there was a server update, run that, restarted everything and am still getting the error.
For me it happens on multiple files all around 200MB-700MB and at any interval (beginning, middle, and end of playback). It will happen about every 3-5 mins as another user has stated above.
I’m getting the same and it’s so annoying. For me it doesn’t matter what it is, I get a shaka3014, shaka3015, shaka3016 error, one of the 3. Happens with longer movies, almost always 1 hour and 45 mins in. Every single time. The only device the videos play on correctly is the Roku. Does it on my laptop in chrome/safari, desktop in chrome/IE/Firefox, PS4 plex app, Xbone plex app. Does not matter if an AVI, MKV or MP4.
I can skip about 5 mins ahead and it’ll continue to play fine and finish the movie, but this is a royal pain on every single device because I have to restart from the beginning and fast forward to about the 1 hour and 50 min mark. I can’t resume and fast forward, it errors immediately.
I even get the errors trying to play from my plex server itself. Happened with the update near the beginning of august, I’m now on the latest, 1.8.1.4139 on a Mac Mini with all updates installed, rebooted everything, still does it.
Just received this error for the first time as well. I’m only 3 mins into a TV show.
Playback Error
An error occurred trying to play "Episode 2".
shaka3016 (Media)
Never had this issue till I updated PMS yesterday.
This is kinda interesting also. After I got that error it keeps saying I’m playing it multiple times! I’m the only user… (/uploads/default/original/3X/f/f/ffeba56717c265839bfccdbbb3fd403b5998b236.jpg “”)
Server Version 1.8.1.4139
Chrome
Converting
Video Direct Steam
Audio Transcoding EAC3 to AAC
It is happening on specific MP3s, which have played fine w Plex in the past and still play correctly when I tested w VLC.
It happens at the start of the MP3
Version 1.7.4.4017
I have re-started PMS several times and the errors are still occurring.
I am getting the same error with multiple files. One after 8:32, one after 53:00. It provides the error in the browser, but on Apple TV and PS4, playback just stops.
I’m on PlexPass, 1.8.2.4209, and it’s happened for the last several releases.
Running in an LXD container on Ubuntu LTS 16.04. ZFS filesystem.
I’m suddenly getting the same error as well, shaka3016, 3015 and 3014 (Media). It happens after about 30 minutes in the Plex Web app (both Chrome and Safari). I’m on MacOS.
There has not been a problem ever before today and I’ve been using plex for years. I’m on 1.8.2.4209 (Plex Pass).
Same for me. It’s been completely flawless. I now have no idea where to watch media, I’ve become so reliant.
Just took the latest version as of todays update (1.8.3.4235) and it’s still doing the same thing. I can bring up plex media player and play the files just fine, I can play them via the app on my samsung tv’s just fine, my android phone works fine, but the web app continues to give me this stupid “shaka3015(Media)” error (Hell, I even installed Emby beside my plex server on the same machine and it serves the media to all clients and the web app just fine).
As a long time user and monthly plex pass member, this sudden change in whatever caused this is really getting annoying, and the lack of a response from the folks at plex in these forums to assist the people who are posting about having the problem is, IMO unacceptable.
