Playback Stuttering and Freezing with Plex for XBOX One
How long do you and them have to be “aware” of the problem before fixing it? C’mon now, this has been identified from dang near the drop and still nothing.
@shpankey It’s a platform issue that affects a whole suite of other applications, but not everyone involved can reproduce the issue (I can’t myself) but I assure you they’re working on it.
Im also having issues with Video and Audio freezing that previously worked before the XB anniversary dash update. a sample of the log file (i think its the right one?) is here http://pastebin.com/bPWhdbfu
Its really annoying me now!
@mcloum said:
Im also having issues with Video and Audio freezing that previously worked before the XB anniversary dash update. a sample of the log file (i think its the right one?) is here 2.3&size=-22&speed=0.6&remaining=10938 (13 live) Signed-inSep 06, 2016 19:55:4 - Pastebin.com
Based on the short log entry your server is unable to keep up with the transcode.
Sep 06, 2016 19:55:50.429 [0x7f84ca3fe700] VERBOSE - * speed => 0.6
A speed value of less than 1 means the server cannot transcode the file in real time. Without knowing anything about your setup there are only a few guesses of what it could be.
  1. Something is causing the video to transcode as well as the audio where previously only the audio needed to transcode. (IE subtitles being enabled, lower selected video quality)
  2. Data isn’t being pulled to the transcoder fast enough (Slow hard drive read, congested network shares)
this issue might be resolved with the latest Xbox One client (not sure). I watched a movie recently and played with no stutter/jutter.
My server is a HP N40L and has been running pretty well for a number of years. Its only ever since the latest xbox dash update that this has started. I have tried bluray rips and just standard SD rips from TV and all files have the same issue. I have a RPi 2 running from the same server which doesnt have this issue and neither does my ipad mini over wifi.
Files ive had previous to the update that worked now no longer work.
The server has 5 3TB WD red drives and i think 8gb of RAM. the only thing letting it down is the CPU but as stated it has been playing MKVs fine for a number of years.
I cant seem to edit my post. I meant to include that the web browser also plays fine. Are there any tests that i can do to gather more evidence?
My xbox is hard wired for what its worth.
I’m not particularly convinced on this one. The Stutter/Judder problem I think is caused by the XBOX One running out of processing power, resulting in micro stutters. This however is dependant on the Bitrate of the material you are watching, and the complexity of the encode. If you watch a higher bitrate file the chances are the XBOX one will have some stutter problems, the lower the bitrate the less likely.
Microsoft I think just never envisioned the play back of high bitrate files. Off a Fixed Disc is a different proposition though…
Just to add, mine is a judder or stutter. Its a full on freeze of audio and video for about 10 seconds then it plays for a another 10 seconds then does the same again.
I meant isnt a judder or stutter…why cant you edit posts here!
You should be able to with the gear icon in the top right corner of your post.
Have you tried a hard reset of the console in case something just isn’t getting cleared out?
Gah that gear icon wasn’t showing at work!
I’ve not but i have uninstalled PLex and re-installed, same result. I’ll try a hard reset.
Sometimes the a hard reset clears out something else that is backing the console up. I used to have to do it pretty frequently because apps would get stuck on my console, but it’s gotten a lot better lately
Don’t forget there are two ways an XBOXone can start. There is a fast start mode that is enabled by default that retains a lot of the os and stuff in memory so that the unit can boot up quickly but it can cause problems. I have seen this with some of the larger games. You can select an option in the system menu for a complete reboot every time you start the XBOXone. I find that is the best way to handle the unit as it gives it a fresh start every time.
Its under the SETTINGS>ALL SETTINGS>POWERMODE & STARTUP menu
Nope doing a hard reset didnt do anything. Neither has the latest dashboard (im in the preview program) I know its either the xbox or the plex client at fault as my Samsung TV has its own plex client and plays the same movies from the same server without issue.
Ever plex client i have in the house works, but the xbox client.
I just looked up a N40L proliant and saw that it is running on an AMD Turion processor. That processor will be a little slow if the server is requesting a full transcode of the file (Video and Audio). Is it possible that something is triggering a transcode on the Xbox Client (Subtitles, Quality Restriction, etc) whereas on the other clients the file is direct playing?
Has anyone got any workarounds e.g another Xbox app to circumnavigate this issue? I have tried the Xbox media player app via dlna however this has a habit of stopping half way through and then there is no way to resume from where you left off. I have this huge Plex films folder and can’t watch any of them in the basement on the Xbox because of this constant freezing issue. Every other plex player in the house works fine.
I’m having this issues with the latest Xboxone beta (dont have the version number right now)
No transcoding, direct play.
`Media
Video Resolution 1080p
Duration 1:47:39
Bitrate 4744 kbps
Width 1916
Height 796
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
Audio Profile lc
Video Profile high
Part
Duration 1:47:39
File **************************************************
Size 3.57 GB
Audio Profile lc
Container MKV
Has Thumbnail 1
Indexes sd
Video Profile high
Codec H264
Bitrate 4744 kbps
Language English
Bit Depth 8
CABAC true
Chroma Subsampling 4:2:0
Color Range tv
Color Space bt709
Duration 1:47:39
Frame Rate 23.976 fps
Frame Rate Mode cfr
Height 796
Level 4.0
Pixel Format yuv420p
Profile high
Ref Frames 5
Scan Type progressive
Title **************************************************
Width 1916
Codec AAC
Channels Stereo
Language English
Audio Channel Layout stereo
Duration 1:47:39
Profile lc
Sampling Rate 48000 Hz`
My server is fine to transcode videos, this happens on basic videos that have no subtitles or DTS audio. Basic MKV and MP3/ACC audio.
I dont think my web browser will be able to direct play the same video files as a Rpi2 can so i dont think its a transcode issue. The xbox client has Direct PLay enabled and i have tried disabling it as others have suggested, no luck.
The only demoniator is either the xbox client or the dashboard version at fault.
The only log you have posted shows that your server could not keep up transcoding the video in the excerpt.
Unfortunately, from what you have posted your server cannot keep up transcoding the video. The Pi2 should be able to direct play almost anything while the Xbox appears to need to transcode your video. The only thing we can really do for you at this point is figure out why the Xbox is transcoding which would be in the log at the start of video playback when the MDE is called.
Just because you have direct play enabled doesnt mean everything will direct play. It only means that direct play is an option for the MDE if all the codecs are playable. Since the Xbox is transcoding something in the log you posted there is something that the Xbox is reporting it cannot play in the file.
