Playlist Issues
Server Version#: 1.14.0.5468
Player Version#: 2.15.0.882-8b488458
If any Version of the Plex Media Player above the mentioned is used then the following Issues are persistent, when controlling the Player Instance from the Android App :
  1. If you start a (self defined) Playlist with the “Play” command, it just contains 1 Item after starting, no matter how many were in it before.
  2. If you Shuffle-Start a Series (not a self defined Playlist), the only thing shuffled is the starting Season, all playing Episodes are in order from here on.
If you use the Player Version posted above all those Controlling Features work fine, but with all later Updates up to the latest 2.22.1.917-2a5a2e01 its just not working. The Android App Version doesnt seem to matter as it updated quite often over the past few months.
This Issue persists for weeks/months and I already posted that here and in the Git Page for the Player.
Please make the newest Player Version controllable again, im sure there are way more broken Features but those i use very often i recognized instantly and are a no-go for me.
Thanks for any Reply, telling me wheter (and possibly when) you will fix that
Guess it’s the same issue I have described in the following post:
Seems like the issue already got confirmed but I am waiting for a fix for some time aswell.
The Issue i opened on Github was just closed a few Hours ago with the following conclusion :
“This working correctly for me on PlexMediaPlayer-2.22.1.917-2a5a2e01-macosx-x86_64 and Plex for Android 7.7.2.7701 (eb613d3g).” from mseeley
So no Fix for Windows as it seems
