On the latest version of Plexamp on iOS, I’m unable to get it to download the entirety of a long playlist. I have a playlist that’s about 9 days long, and I’d like to download the whole thing. I set up the download on the playlist with the “Maximum” length as described in the release notes, but it isn’t downloading more than 3 days, 2 hours (I assume this is actually around 72 hours and it’s just a display thing).
Does the maximum setting not do what I expect it to? I previously was able to get around this by putting everything into one album and downloading that, but now that also seems to be limited to 72 hours.
Maximum is 72 hours. It’s there so that if you start with a smaller playlist and want to specify “hey, keep downloading everything up to 72 hours as I add to it”
Thanks for clarifying. I found that label pretty unintuitive. Is there any plan to expand the download limit past 72 hours? I know it’s already gone up over the years, but it’s still not enough for my use case. I’ve manually chunked my playlist into 72 hour playlists, but it’s pretty tedious.
