And if this helps, it usually crashes after watching something for an hour or more
Running EXT4 or BTRFS ?
ok.
let this sit on 1.13.2. See if PMS remains stable
If PMS also reboots daily, the issue isn’t PMS, it’s the OS or hardware in that order
I would also recommend you upgrade to 6.2 U2 at next earliest convenience
i dont believe it reboots daily, how would i check that in PMS?
i have an uptime of 117 days in DSM
Sorry… Crashing / rebooting. It has been a rough week.
PMS crash should not happen.
Restart / reboot is where my words got crossed
PMS 1.13.5 might fail to respond (jammed up) but not crash
This is why I have given you 1.13.2
ohhh got it, i hear ya. Same here!
did you get what you were looking for from the first set of commands i posted alittle earlier?
Yes, all good.
As background info:
- PMS 1.13.5 introduced “ServerBindInterface” which allows you to select which adapter the HTTP server listens on.
- Because our Synology boxes have multiple, and support Docker, it was necessary but also a challenge to implement.
- After collecting a ton more data from actual use cases, enough information is now in hand to refine it and provide what is really needed.
- This is what they are doing
Until that time, greater stability is had by sticking with the ‘as it was’ versions prior to 1.13.5
You’re fine. It occurs even in bonded systems. I have 4x 802.11ad and it occurs.
got it, thanks for the clarifications.
So 6.2 update 2 is okay to use with PMS 13.2?
If so i will upgrade now
Yes. I updated the installer for all of 6.2 long ago.
okay will do
And i will send over those kernel logs if PMS crashes on 13.2
It’s been so long since I upgraded one. Make sure it reboots
will do, thanks for the heads up
Of course. I know of that part because in 6.2, all the rules for UDEV changed.
Worse-case scenario: Uninstall the package and re-install it. It will touch everything it needs.
( I do all checks and corrections with each install/upgrade of PMS )
oh okay, uninstall and reinstall PMS 13.2 im assuming if PMS does not work after upgrading
100% correct.
If it still fails to work correctly:
- Stop PMS
- Open File Station
- Drill in Plex -> Plex Media Server
- Right-click
Logs->Compress to Logs.zip - Let me give a read to see what the H… is going on
okay, i will send those logs as well as the kernel logs via ssh you posted earlier
IF all is well, kernel logs not needed
