PLEX trying to connect to two HDHomeRun devices that no longer exists on my home network
Server Version#:1.18.4.2171-ac2afe5f8
I have PLEX running on a Synology DS1817+ w/ DSM 6.2.2-24922 Update 4.
Is there a config file I can manually edit to prevent these messages upon PLEX startup? PLEX is trying to connect to two different old HDHomeRun DVR devices (192.168.1.9 and 192.168.1.156) I used to have on my local network. I currently do not have PLEX DVR even enabled.
Dec 28, 2019 19:07:16.380 [0x7f92550d9700] INFO - Plex Media Server v1.18.4.2171-ac2afe5f8 - Synology DS1817+ x86_64 - build: linux-x86_64 synology - GMT -06:00
Dec 28, 2019 19:07:16.380 [0x7f92550d9700] INFO - Linux version: DSM 6.2.2.24922-4, language: en-US
Dec 28, 2019 19:07:16.380 [0x7f92550d9700] INFO - Processor Intel® Atom™ CPU C2538 @ 2.40GHz
Dec 28, 2019 19:07:16.380 [0x7f92550d9700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
Dec 28, 2019 19:07:16.712 [0x7f925f77d740] INFO - OCSP: Successfully retrieved response from cache.
Dec 28, 2019 19:07:27.933 [0x7f9235c88700] INFO - AutoUpdate: no updates available
Dec 28, 2019 19:07:30.635 [0x7f924cdb9700] ERROR - Error issuing curl_easy_perform(handle): 7
Dec 28, 2019 19:07:30.635 [0x7f924cdb9700] WARN - HTTP error requesting GET http://192.168.1.9:80/discover.json (0, No error) (Failed to connect to 192.168.1.9 port 80: No route to host)
Dec 28, 2019 19:07:30.637 [0x7f924cdb9700] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1057361B, marking as dead.
Dec 28, 2019 19:07:31.292 [0x7f924d683700] ERROR - getaddrinfo(172-17-0-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -5
Dec 28, 2019 19:07:33.643 [0x7f924cdb9700] ERROR - Error issuing curl_easy_perform(handle): 7
Dec 28, 2019 19:07:33.643 [0x7f924cdb9700] WARN - HTTP error requesting GET http://192.168.1.156:80/discover.json (0, No error) (Failed to connect to 192.168.1.156 port 80: No route to host)
Dec 28, 2019 19:07:33.645 [0x7f924cdb9700] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1073980D, marking as dead.
Dec 28, 2019 19:07:33.887 [0x7f9236840700] ERROR - getaddrinfo(172-17-0-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -5
