Plex 1.7.3 Tuner Usage Issue
Just upgraded to 1.7.3 and wanted to check out tuner usage so tried to start 5 recordings. I have 2 HDHR Connects and one HDHR Prime so a total of 7 tuners available to Plex. Noticed this odd issue on 1.7.2 but wanted to try it on 1.7.3. It appear that Plex will not start a recording on the Prime device. When I tried to schedule the 5th recording I get an error about conflicts. Looking at the devices in the DVR settings and what is recording does not reflect what each tuner is showing. Plex DVR shows 2 recordings on the first Connect, one recording on the second Connect, and one recording on the Prime which does not correlate with the tuner usage on each device. Devices show each Connect tuner is in use and none of the Prime tuners are being used. Attaching screenshot showing DVR and tuners and logs. Hoping a Plex Employee @keithah will take a look and give their thoughts.
You can’t mix an match tuners types because only one set of EPG data will be used. either OTA or cable.
Prime is only setup for local channels broadcast by cable company. Have had 7 shows recording in the past so I know it worked fine before.
I’m telling you it doesn’t. If it did, it was a unsupported fluke
