Plex agents do not recognize some titles with colons
Hi
This issue has been discussed in several topics already but I only found workarounds that don’t work for my case.
Plex doesn’t recognize some of my documentaries with a colon in the title.
For example: “Bob Ross: Happy painter” or “Steve Jobs: the man in the machine”.
I use The TVDB and Moviedb as agents, the 2 documentaires exist on the MovieDB website but Plex does not find them because of the colon in the title i suppose.
I tried to replace the colon with other signs or juste remove it “Bob Ross - Happy painter” or “Bob Ross Happy painter” but it doesn’t work. The title of the documentary is not even added without the posters, nothing happens. Only if I add S01E01 in the name plex thinks it’s a tv show and adds the title but without any posters or background from the TvDB or MovieDB.
If I use filebot to rename it, Filebot wants to add the colon in the title but it’s not possible to add colons in filenames so I’m stuck again. I hope someone has found a solution for this.
Thanks for any help or advice.
Steve Jobs The Man in the Machine (2015) works for me
Other one not avail for me, but same pattern should be used
Thanks for testing, strange, the same title does not work for me.
I use Plex server with Freenas, I could try it with my other NAS (netgear) to see if there’s a difference but I should be the same result. I’ll post my results later.
I have that as a folder, with the actual movie below it
yes, same here I always use a folder + the documentary of movie in the folder with the same name
And you did place it in a movie library?
And forgot, since on Linux, also check that PMS actually have rights to the file/directory
Hmm sorry that was really stupid of me, that was the problem indeed.
I put the documentary under TVShows but I should have put it with my Movies.
I just moved both files to the Movies library/share and now it’s recognized immediately.
Thank you for the quick support, the problem is solved for both files now!
