PLEX and SUBs (won't play properly)
Server Version#:1.18.4.2171-ac2afe5f8
Player Version#: Version 4.20.1 (all player has the issues)
My Anime’s won’t play properly when I add subs, is there a way to fix this?
without sub it plays great
but with it plays like above and can’t see nothing. moves extremely slow or don’t. even play at all.
Yes, this is known problem which has been going on a while. .
There are several threads about this.
Several workarounds including removing the intel driver shared object
“/volume1/@appstore/Plex Media Server/lib/dri/iHD_drv_video.so”
and restart PMS.
For example see
Thanks, I haven’t read all the comments yet, I would like to keep my current version and not upgrade, as since this last update the server works smoother and faster so I rather not downgrade to 1.18.0 public. the“/volume1/@appstore/Plex Media Server/lib/dri/iHD_drv_video.so” work around where can I find this on a Synology Nas?
On a QNAP you can turn off hardware acceleration and it works.
Yes, I keep the latest version too. You have to remove iHD_drv_video.so every time you upgrade. The issue is still in the process of being addressed.
You’ll need to ssh into your NAS to get command line access to remove the iHD_drv_video.so file above. For example see post 32 in the thread I linked to above.
ok I will try that soon but for now I Turn off hardware accelerated transcoding and works, but I feel turning that off will slow things down.
Yes. You may see buffering when transcoding high bit-rate 1080p video. Transcoding 4K video in software will definitely fail.
Deleting the offending driver or falling back to an unaffected version of Plex is the preferred workaround. It forces Plex to use an older, different (but working) driver when hardware acceleration is enabled.
ok thanks I will do the delete of the driver. will check on how to do that. I don’t want to downgrade and I will need the hardware accelerated transcoding on.
deleted and its working with accretion on thanks a lot for the help
