click on my username/avatar and click Message button
Sent Android logs and server logs (Plex on web works fine though)- just android issues
thanks. was also wondering if yâall have tried updating android to 8.18 which was released a couple days ago. looks like at lease some of yâall are still running 8.17.125325
No jajaja. I want to say: How can i get the logs from de plex windows app
Remote control dont works
I think iâve sent. Do you received it?
I made a new pms on my laptop using my cloud home jus as a library. Then the android app seems to work.
I think the problem is that the pms server software on the my cloud home doesnât work in combined with the android app.
And the remote control works in your new pms??
@jambo can you please try setting the âallow insecure connectionsâ setting on the Android TV app to âon the local networkâ.
possibly changing the secure connection setting in network setting of server to disabled. but only do that if the setting above does not work
@BigWheel Iâve had the same issues as others have described above with MyCloudHome and Android TV. Changing the âallow insecure connectionsâ and âon the local networkâ seemed to fix the issue for me.
Good for me plex working on my tv and my Phone now. Thank you
SoâŠchanging the âallow insecure connectionsâ and âon the local networkâ didnât work for me even after clearing cache/deleting data and signing back in but changing the secure connection setting in network setting of server to âdisabledâ did.
Both Android app and Chromecast work now thanks! But what does that mean now- prefer to have some âsecurityâ. Can anyone just connect now?
@Chrst1201 you have a bunch of various errors in log. some relating to certificate errors and others that are usually related to DNS issues. if you have not yet please try what I mentioned above Plex + Android tv not working - #30 by BigWheel
I would also maybe change your DNS to something like Googleâs or Cloudfareâs in your router
no one can just connect. it is to encrypt the connection so someone who knows how cannot understand the traffic.
DNS can have an effect on this too so it might be a good idea to change your DNS to something like Googleâs or Clourfareâs as well
still trying to figure out what is going on though. I asked our QA guys to check connecting to out WDMyCloudHome and they are not having any issues with it so it is hard to figure out why yâall are.
I have tried all you asked for. I dont know what can i do now
