Plex Arcade: Change Retroarch Options
So I’ve got my games scanned and they work, but the bilinear filtering option for retroarch is obviously turned on, the image is WAY too soft and blurry. How do we change the video options such as bilinear filtering, and enable options such as interger scaling, use shaders, etc as the standalone Retroarch supports.
I know what you mean. There’s currently no rendering configuration. Choosing an output resolution and scaling method would be really beneficial for the sprite games.
Thanks, hopefully those options will be enabled soon. Just a simple toggle to disable bilinear filtering would suffice for now, until the more granular options can be added. Those pixels need to shine! LOL
It’s gonna certainly be necessary.
As it stands, you can only play games on your PC or your phone, in which case… why wouldn’t you just use retroarch to start?
On a 4K TV, without any sort of configuration, Gameboy Advance games look like this. N64 games are only marginally better, being about 1/6 of the screen.
Following… I would agree - far too blurry… but retroarch has the options… just need to know where the config file is :slight_smile:
it’s an android tv bug, we’re working with Parsec to fix.
