Plex auto refreshing metadata
Hi all,
Hoping someone can help but I’ve noticed recently that Plex is automatically refreshing metadata randomly without anything in settings have changed. This is annoying because I’ve set the metadata a certain way and don’t want an auto-refresh. In many instances its also incorrectly matching the movie title incorrectly.
Anyone else having this problem or know how to fix this? Is it a new server issue?
This was introduced with Plex Media Server 1.25.4.5426 on Jan 20 - (Library) Refresh movie metadata periodically during scheduled tasks (#13250)
It says movie metadata, but it actually affects TV shows as well. You can disable this in Scheduled Tasks by unchecking “Refresh library metadata periodically”.
Hi this must be a bug then because I’ve never had that option checked and looked now and it’s still unchecked. Any other ideas?
Did you perhaps switch/upgrade agents recently? How often does this “auto-refresh” happen? The feature I was talking about only refreshes metadata, but does not change the name or anything else.
sorry for the late reply. No i havent changed anything in the server settings for a long time. And i can’t tell it seems to be doing it on its own. I would guess during the normal maintenance hours
