Plex Certificate "404" -- Unable to obtain Certificate from cloud
You’re the best :+1:
Good luck for the future
@ChuckPa Sorry to bother you again, Did you see my new topic as you asked me to do?
@ChuckPa After certificate reset none of the remote devices no longer see the server.
The symptoms are:
  1. I can curl https://:32400$server no issues (from external locations).
  2. The remote access status most of the time is green
  3. All of the remote devices are unable to connect.
@yevaman44
Yes, I see it. I am going to ask one of the Windows guys to help.
I am NOT a windows guy. Your issue is Remote Access on Windows.
Ok , thks, hope you can contact them. You’re very helpfull, I wish I was a lunix user ! :slight_smile:
Last time I had a problem, nobody answerd me in windows section.
Choose a good guy that you know you can rely on :slight_smile:
Can you gimme a name that i can “poke” him in my thread ?
@SergeiFranco
Please verify DEBUG logging ON, VERBOSE logging OFF.
Restart the server.
Wait 1 minute
Download the Logs (settings - server - troubleshooting)
Attach the ZIP
Here is one that i just got where they debug as enabled. Sorry, having technical difficulties. Plex Media Server Logs_2020-10-03_12-00-43.zip (4.9 MB)
@ChuckPa Here are the logs.
Thank you.
@SergeiFranco
Your certificate is fine now.
Oct 04, 2020 08:01:40.054 [0x7f51e66a7e80] DEBUG - ChangestampAllocator: initialized to 14569591
Oct 04, 2020 08:01:40.054 [0x7f51e66a7e80] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Oct 04, 2020 08:01:40.056 [0x7f51e66a7e80] DEBUG - Running migrations. (EPG 0)
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] DEBUG - [CERT] Installed certificate with fingerprint 34:60:19:03:5a:13:84:bc:02:55:e7:76:fc:86:01:60:b2:e5:46:52.
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] DEBUG - [CERT] Installed new private key.
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] DEBUG - [CERT] Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.7128b24764c144a89582e546502fe122.plex.direct
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] DEBUG - [CERT/OCSP] Stapling requests will be made to 'http://ocsp.digicert.com/'.
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Oct 04, 2020 08:01:40.069 [0x7f51e66a7e80] DEBUG - [CERT] Installed intermediate certificate.
I see another issue. i will chat with operations
Oct 04, 2020 08:01:50.154 [0x7f515f7fe700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct 04, 2020 08:01:50.155 [0x7f515f7fe700] DEBUG - MyPlex: Published Mapping State response was 422
Oct 04, 2020 08:01:50.155 [0x7f515f7fe700] DEBUG - MyPlex: Got response for 21d21380beaa553cdc3982e5e8adbbefff54880b ~ registered :0
Oct 04, 2020 08:01:50.155 [0x7f515f7fe700] DEBUG - MyPlex: updating mapped state - current state: 'Not Mapped'
Oct 04, 2020 08:01:50.155 [0x7f515f7fe700] DEBUG - MyPlex: mapping state set to 'Not Mapped'.
Oct 04, 2020 08:01:50.281 [0x7f51d2ecc700] DEBUG - Auth: authenticated user 1 as SergeiFranco
@ChuckPa Restarted all the clients (Android, Fire TV and web to no avail).
Sergio,
I need to wait now a bit while Operations and Plex.tv teams look at what’s happening.
The “422” error is no longer a certificate problem. There is something else going on.
It’s time for me to be educated more
@Erics347
I am going to ask you the same I ask everyone.
Please turn VERBOSE logging OFF unless requested
It outputs about 25 lines of junk (each packet exchanged) for every 1 good line I can use.
VERBOSE is OFF by default.
DEBUG is ON by default.
You are experiencing the ‘422’ issue seen above by Sergei.
I’m awaiting their response
Yes i turned Verbose off and have the normal one enabled
Did you remember to SAVE? :wink:
Hey Chuck!
Thanks for all this help dude!
Any chance you could take a look at mine please?
Restarted collected logs and can see:
Oct 03, 2020 21:04:48.640 [0x70000a8fa000] ERROR - CERT: Could not fetch certificate from the cloud: 404
Cert. reset
Restart the server
Working like a dream! appreciate the help dude!
@ChuckPA need my cert kicked - getting 404 in the log.
Server Wally account whitemystic
Done,
You may restart it now.
I saw SSL was disabled.
