Plex Certificate "404" -- Unable to obtain Certificate from cloud
Hello @ChuckPa,
Got the same problem :
ERROR - CERT: Could not fetch certificate from the cloud: 404
and after reboot of PMS :
DEBUG - CERT: Installed intermediate certificate.
If you can reset the certificate.
@Solidus756
1, Nas has not been seen in almost 4 years. Would you like it removed?
2. QuickBox appears to be the intended host. Correct?
To all reading this thread. The log entries @Solidus756 shows are definitive certificate problems.
hi @chuckpa, I’m seeing the same issue here with my cert (have been for a number of days now). non-secure is fine, secure doesn’t work.
THANKS!
@icypermission
Certificate reset.
Please restart the server.
In your case, Plex.tv is showing what you’re seeing too.
how do you restart the server ?
I don’t use windows.
How do you stop and start a program?
If all else fails, I suppose you can reboot it
@ChuckPa thank you! All good here.
@yevaman44 plex icon should be in you system tray in the bottom right by the clock. right click and choose exit
Yes thx, I’ve done that, but problem still remains.; :frowning:
@yevaman44
Start a new thread with appropriate title and tags.
Post freshly downloaded logs.
Then @chuckpa ping me.
I will take a look.
ok thx
@ChuckPa
here’s the new thread :
Ok, sorry about that. Here is an update one. Thank you. Plex Media Server Logs_2020-10-03_11-23-04.zip (5.3 MB)
@ChuckPa Another error here, too.
Oct 03, 2020 10:56:37.139 [0x70000d41f000] ERROR - CERT: Could not fetch certificate from the cloud: 404
I have a server log zip ready to go. How can I PM you an attachment? Thank you!
@prince_1999
  1. I’ve reset the Mac mini’s certificate. Please restart the server
  2. Would you like the iMac removed while I’m here ?
That’s it @ChuckPa.
Nas is very old
@Solidus756
Quickbox reset. You may restart.
NAS untouched.
(wasn’t clear which was which so I opted for most recent :wink: )
Yes, thank you!
@ChuckPa
sorry for the imprecise answer :sweat_smile:
You could remove NAS but don’t worry, it will be for another time, you have enough work for now.
Otherwise thank you, my Plex is back and the family is happy.
@prince_1999 – Removed
@Solidus756 – I was still sitting on that page – Removed.
