Plex Certificate "404" -- Unable to obtain Certificate from cloud
Hi I have problems connecting to my server from outside my local network.
Server Synology DS412+
Logs.rar (3.1 MB)
Plex Media Server Logs_2020-10-05_04-53-56.zip (2.4 MB) Server Version#: Version 1.20.1.3252
Player Version#: Version 8.7.1.2031
Hi I hope someone can help me.
I have been having problems getting remote access to my Plex server on my Synology NAS DS412+
I have setup port forwarding on my router from my external IP address on port 32400 to my internal IP address on port 32400 but it says its online for 5 sec after that it says, not available from outside your network.
I have also tried to setup UPnP and not even that helps.
I have configurated public IP address for my router and my NAS server is connected to my router
directly.
I just want to say that my server has been working for 2 years but for 4 - 5 days ago it stopped working.
Hope someone can help me.
@BubbiBjQrn
You are in the wrong thread.
Please post over here:
Also, please turn VERBOSE logging OFF. VERBOSE only hampers our efforts to help.
(Save the changes after you reset it)
PS: You have a problem with the certificate your machine is using.
Oct 05, 2020 04:51:34.701 [0x7fe4d4b43700] VERBOSE - It took 0.0 sec to serialize a list with 1 elements.
Oct 05, 2020 04:51:34.701 [0x7fe4dcdd1700] DEBUG - Completed: [127.0.0.1:58949] 200 GET /servers (6 live) GZIP 201ms 493 bytes
Oct 05, 2020 04:51:34.719 [0x7fe4dcdd1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 05, 2020 04:51:34.722 [0x7fe4d688f700] ERROR - Error issuing curl_easy_perform(handle): 60
Oct 05, 2020 04:51:34.722 [0x7fe4d688f700] WARN - HTTP error requesting GET https://87-61-89-242.78b92
TLS V1 is no longer used.
Hi @ChuckPa, looks like I have the same 404 issue too. Server name is kingNAS. It’s shut down now. Thanks!
Oct 05, 2020 11:36:54.752 [0928] ERROR - CERT: Could not fetch certificate from the cloud: 404
@kingaffiliation
I have reset the certificate.
Thank you for having it shut down.
You can start now
Excellent! Thanks so much for your quick response. Looks fixed now.
Thanks I have posted in the other thread.
/BubbiBjQrn
@ChuckPa
Oct 05, 2020 13:54:09.420 [0x7fed31dad700] DEBUG - HTTP 404 response from POST https://plex.tv/devices/ffc81eb0bf482ac218cc715e0e2d6c4665324c3a/certificate?version=3&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 05, 2020 13:54:09.421 [0x7fed31dad700] ERROR - CERT: Could not fetch certificate from the cloud: 404
Server name is Apollo and it’s been stopped.
Old “Zeus” removed.
Apollo reset
OK to startup
All fixed, thanks!
Server NUC is stopped, date is synced
5 Oct 21:14:44 ntpdate[11030]: adjust time server 192.36.143.130 offset 0.000433 sec
@daniel_33k_org
Certificate reset
Restart as soon as possible,
Seems good :slight_smile:
Oct 05, 2020 21:30:05.182 [0x7f0f2ffff700] INFO - [CERT/OCSP] No relevant response in cache.
Oct 05, 2020 21:30:05.182 [0x7f0f2ffff700] INFO - [CERT/OCSP] Couldn’t install the cached response; fetching from network.
Oct 05, 2020 21:30:05.398 [0x7f0ed9ffb700] INFO - [CERT/OCSP] Successfully retrieved response.
Yep. LGTM :slight_smile:
Thanks man, good job fixing issues for all users
My ‘poor button pushing finger’ will need a vacation when this is all over :wink:
Got a “Oct 05, 2020 18:14:00.132 [0x147461dbd700] ERROR - CERT: Could not fetch certificate from the cloud: 404”
Server name: nas-lian
thanks
@vertiger
Certificate reset.
You may restart the host.
Hi Chuck,
Oct 05, 2020 12:32:21.839 [11452] ERROR - CERT: Could not fetch certificate from the cloud: 404
Same error here as well.
Server name: Colossus
Thanks!
works now,
thanks
@kmount4
Certificate reset
You may restart PMS
