Plex Certificate "404" -- Unable to obtain Certificate from cloud
Thank you! Working again!
@ChuckPa
Oct 05, 2020 22:59:09.198 [2172] ERROR - CERT: Could not fetch certificate from the cloud: 404
I am having the same issue
Server name : DanaPlex
Thanks!
@DanaFW
Cert reset.
You may restart now
@ChuckPa If you’re still around my Shield Android TV server is off and ready for a cert reset. Thanks.
Reset.
you may start the Nvidia Shield
@ChuckPa will this also work with 429 errors? I can’t get secure connections working but get a 429 instead of a 404. (CERT: Could not fetch certificate from the cloud: 429)
Oct 06, 2020 12:10:05.527 [4980] ERROR - CERT: Could not fetch certificate from the cloud: 404
Server Name: PeterNAS
Is shutdown at the moment
Hello @ChuckPa, im getting the same 404 errors, debug logs attached.
Plex Media Server Logs_2020-10-06_07-40-01.zip (974.8 KB)
Also results of openssl s_client -showcerts -connect 127.0.0.1:32400
:/usr/local/plexdata/Plex Media Server/Logs # openssl s_client -showcerts -connect 127.0.0.1:32400
CONNECTED(00000004)
34380903576:error:140790E5:SSL routines:ssl23_write:ssl handshake failure:/usr/src/crypto/openssl/ssl/s23_lib.c:177:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 307 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1601984666
    Timeout   : 300 (sec)
    Verify return code: 0 (ok)
Server is currently shutdown, whenever you have time to work your magic!
Any word by chance on how to fix this issue? Thank you
@peterkrol12 - certificate reset , OK to startup
@bri2785 - Certificate reset, dead server removed, OK to startup
@animazing - 64 servers listed (most are dead) – cleaning at this time
Thanks, it’s working!
Works perfect now, thank you!!
Looks like I need a certificate reset as well.
Oct 06, 2020 08:46:49.434 [3904] DEBUG - HTTP 404 response from POST https://plex.tv/devices/dd42af85415df9d4a7d8af8d777e86e730718893/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 06, 2020 08:46:49.435 [3904] ERROR - CERT: Could not fetch certificate from the cloud: 404
@Animazing
Please read your PM.
Can you reset the cirt please. I will stop server and sync time. Thank you
@Erics347
Let me know when ready – I’m right here
@shane.golden
Dead server removed.
Certificate reset
You may restart Tiki
Ok. Server shut down. And time synced
@Erics347
Done, you may start the server
All good now, thanks
