Fixed!
@ChuckPa I am unable to connect remotely and I think it is due to this certificate issue. Can you try revoking it as well?
Thank you.
Remote access failures have not been a definitive symptom.
Seeing the entry ‘404’ in the server logs at startup with the message (thread title) is definitive .
Can you confirm? I will review them if you wish
Certificate revoked.
You may now start PMS.
working now
I love you
When I press the login button in Chrome it will not show the login dialog box in plex.tv domain. It works in firefox (cleaned cache - restarted everything)
Here is the error I get!
I can’t help with browser issues here in this thread.
This thread is dedicated to server certificate 404 and 429 errors.
Would you please create a fresh thread, tagging it Plex/Web and for your host platform (windows, linux, or mac ) ?
@ChuckPa I am also having the certificate 404 issue.
htpc or titan ? (titan looks unused?)
@ChuckPa htpc.
titan can be removed.
Will do.
Please shutdown the server.
I’ll reset it in a minute.
@ChuckPa worked like a charm. You are a champion!
thanks but I’m no champion.
I’m just the guy with a big
Server is stopped. Thanks in advance, dude!
Oct 02, 2020 16:10:42.774 [0x7f1b7d7fa700] DEBUG - HTTP 404 response from POST https://plex.tv/devices/120720a2d6a4569801ad88ca07c8a92589e41516/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 02, 2020 16:10:42.774 [0x7f1b7d7fa700] ERROR - CERT: Could not fetch certificate from the cloud: 404
@ChuckPa
RAMPED
hola estoy experimentando problemas con mi acceso remoto fuera de mi red alguien me puede ayudar llevo 4 o 5 dias sin funcionar
This thread is dedicated to server certificates.
Please create a new thread for your remote access problem.
You have several RAMPED.
I removed the instances of RAMPED which were over 2 years old and not seen since then.
They also had no shared users
I then reset the cert for the current one (seen 45 minutes ago)
You may restart now
Boom…Done. Muchas Gracias!!!
Way to swing that hammer!
CR
