Plex Certificate "404" -- Unable to obtain Certificate from cloud
Just woke up – I will go through the above posts and catch up.
@Erics347
  1. Please turn VERBOSE logging back off. It does nothing but lose data and make my job 10x harder.
  2. I cannot use the logs you provided because of it.
Thanks dude ! Sorry for that ! Hope you spend a good night ! :slight_smile:
@paul_roche - Certificate Reset. Please restart
@Pyrographic
@F_NX
@SergeiFranco
Certs reset - Please restart the server.
@yevaman44
I see 3 servers.
Which server(s)
Sly_plex
You can restart all
Everything OK on my end, thanks a lot !
@jswain
cert reset - please restart
@yevaman44
  1. I have reset Plex_Sly . You may restart it
  2. Sylvain has not been online for 2 years - It has a valid certificate - skipped
  3. Plex sur Passeport has not been online for 3 years - It has a valid certificate - skipped.
@Sukopro
Certificate reset - You may restart the server.
FUTURE: PLEASE turn VERBOSE logging OFF!
In the future , we will not be able to help if you do not follow with our requests.
Thanks for your intervention.
but it’ve got a question : what do you mean by " restart"
What shall I do after you did that ?
Restart computer ?
Restart the server
Hi I’m getting remote access issuers, could you reset my certificate please
@DEFSQUAD
Certificate reset.
@chuckpa I had tried to restart the server…Same problem… it goes “green” few second then red.
Unable to acces…
Prehaprs I don’t restart the server has it should be. I just went to the tray icon, close the media server and re-lauchh it… Thats it ?
thank you ill run some tests
looking good, thank you :slight_smile:
@yevaman44
Then you do not have a certificate problem.
This is why i do no blindly (when I can help it) issue certificate resets.
There are many factors which effect remote access.
Please do the following:
  1. Verify DEBUG logging is enabled, VERBOSE logging disabled (Settings - Server - General - Show Advanced)
  2. Restart the server
  3. Let it sit completely idle for 3 minutes
  4. Download the logs
  5. Create a fresh thread which includes “Remote Access” in the title.
  6. Attach the ZIP logs.
