Plex client on Samsung Tizen crash on subsequent starup
Server Version#: 1.15.1.707
Player Version#: 3.84.3
TV Model#: UE65KS8005
TV firmware version: T-JZMDEUC-1231.1,BT-S
Sub-micom-version: T-JZMDEUS-1006
  1. install plex client from samsung apps store.
  2. start plex client
  3. link account plex.tv/link
  4. observe plex client working
  5. turn off tv
  6. start plex client
  7. observe crash
So it works the first time, but every subsequent start of application crashes.
When it crashes it seems like the login of local user is present in the upper left corner, but it’s way to small to make out, just a few pixels.
There is also a lot of white text (also to small to make out) printed down the screen.
The only way to recover after rebooting tv it to uninstall the plex client app, and reinstall it, again linking account for a one time chance of viewing your media before you have to repeat the process all over again the next time.
This issue has been present now since mid 2018, whereas before that everything was working flawlessly.
I see many others also complain about this issue, but seemingly very little engagement by the plex team to resolve the issue. I has been half a year, I’m a patient man, but I must admit, it’s wearing very thin now.
If everyone else who experience this issue can add their tv model and firmware version, maybe a pattern can be indentified.
To find your Samsung TV model and firmware version. (at least on my TV)
  1. press home button
  2. select settings all the way to the left.
  3. go all the way down to Customer Support
  4. 2nd from the bottom select Contact Samsung
In the latest version the screen looks a little different after crash. Less but bigger text visible on screen
I also have this issue on my 65KS8500.
Same issue on my 55KU6409 after forced Plex app update on Februrary 15th.
What helped me so far: uninstall Plex app, install Plex beta app (Plex TV v2 Beta for Samsung 2016+ UHD Devices) and update Plex server to version 1.14.1.5488. At least now the app starts again and is able to play videos. Restarted the app and the TV, started playback where I left of several times - so far it worked.
This has been going on over a month. Resetting the hub will make it work again. Come back to it some time later and its crashed again.
Samsung says they will contact the app provider but told me to also contact them. I see no way to contact them except posting this in the forums. As a lifetime Plex Pass holder, it’s unacceptable to NOT be able to contact support about this issue.
Hopefully someone at Plex is looking at this thread and can take it up with the developers for a fix.
This is not an issue with the TV or their OS. I started to notice this problem when I saw some GUI changes to the Plex app.
@Hypnosis4u2nv how do you reset the hub exactly? Sounds easier than uninstalling plex, reinstalling and reauthenticate.
Actually there are several threads on this issue and yes Plex is looking into it.
Go into Settings, Support and Self Diagnosis…
thanks. I’ll try that the next time it crashes, wont be long x-)
Did you try installing the preview version manually and using that until they get the problem solved?
Just installed it, I will get back to you if it continues to occur after exiting out.
I’ve had no issues with the preview build… Thx
That option is actually grayed out on my TV. So I can’t select it. :S
You need to be in an input, any HDMI port. It wont work if you’re in any of the Apps.
ahh, that worked. However, it was even more hassel to set up the hub again than it is to remove and reinstall plex :roll_eyes: so not doing that again.
The preview used to work for me before (I’ve been having issues since fall 2018.) But at some point the side install and the main install seem to merge to one install and it doesn’t help any more. So a proper fix on the main version from the plex team would be much appreciated!
So far the sideloaded preview is working. I don’t think it will be long before samsung pushes the new version.
The Hub is definitely a hassle, but you might find yourself in this predicament again at some point and it might help to reset the hub. Samsung was no help, they made me do a complete TV reset which sucked even more as I had it calibrated and the settings were lost.
It’s almost like I’m considering getting a keyboard for the TV so I can type inn my email and passord. Does Samsung support Bluetooth naively? =)
That hurts, like paid for calibration with a light technician?
You can use a wireless USB dongle for keyboard.
And yes, I paid for a calibration. I just cant find the paperwork for the settings…
I have this issue on my un55ks8500f
