Plex Cloud vs VPS - why we went with a VPS
@KarlDag said:
Did your other account ALSO get terminated?
Yes, unfortunately. I had bought 3 in total, one totally unused still and all gone simultaneously. I hadn’t expected that tbh. I mean I always knew it wouldn’t last forever, but I thought I’d lose them one by one, not all at once.
With Rclone gone from Amazon that sure doesn’t leave many options open, I’m reluctant to open a genuine Gsuite account with the risk of losing Rclone on that as well, or worse, the entire account.
Also it would turn out to be more costly than we were prepared to spend, so for now, we’re going back to our server at home fulltime again until hopefully a solution presents itself.
Yeahz I’m surprised too, everything fell off a cliff within a week.
ACD has been a pain in the butt ever since I started using it… Sure it’s cheaper, but all the tools I tried with it (rclone, ACD_cli, netdrive, stablebit, expandrive) had issues with it. Speed was always slower than Google drive.
I think any tool that encrypts or obfuscates your data will be fine e with Google, I’m more worried about them enforcing their 1tb limit…
As for price, 10$/month will always be cheaper than replacing dying drives if you have more than 3 or 4 large drives in your system…
How to get plexdrive to start up after rebot anyway can explain how the startup script works
I will think about this for a while, it’s all too new and things are happening too fast to make any informed decisions yet.
It would take a few months to reupload everything to Google anyway, with no easy means to copy stuff across from ACD anymore.
I’m still hoping Rclone will be approved again but I admit things are not looking good right now…
It’s a big ■■■■!
I’m giving up, it’s too complicated, I go back to the traditional system, I canceled my VPS, canceled the renewal of Amazon Drive and bought a brand new Lacie 2big Thunderbolt2 16Tb!
This is kind of the blind leading the blind, but here is what worked for me. I found plexmediaserver.service in this folder
/etc/systemd/system/multi-user.target.wants, I duplicated and renamed it to plexdrive.service and then blanked it out and put the following in it:
[Unit]
Description=Plexdrive
AssertPathIsDirectory=/media/PlexDrive
After=network-online.target
[Service]
Type=simple
ExecStart=/usr/sbin/plexdrive --chunk-size=2.5M --clear-chunk-max-size=80G --uid=111 --gid=117 -o allow_other /media/PlexDrive
ExecStop=/bin/fusermount -u /media/PlexDrvie
Restart=on-abort
[Install]
WantedBy=default.target
Of course your location of plexdrive.bin and folder your mounting to might be all different and I am not 100% sure if this is the most correct way to do this but it seems to be working fine. Linux Gurus please chime in.
@javiervitorero@me.com said:
It’s a big ****!
When you start to exceed 16TB, you’ll begin to see why cloud storage is enticing. :wink:
Surely, but for now is not interesting, too many obstacles and too much time invested for nothing!
Can’t say I blame you!
anyone figure out how to transfer from ACD to GD since the rclone ban? I don’t want to upload it all again
I use https://www.cloudhq.net and it seems to do the trick pretty well. Also (and this is perfect for me) it’s idiot-proof!! :wink:
$19.80/month (billed monthly $119.88 if billed annually) seems pretty expensive. I see they have a 15 day free trial so it would be a way to quickly rescue your files from ACD.
I was using ACD as my backup for Google Drive copying using rclone on a VPS from Bytesized with 1GB network & unlimited bandwidth which costs me €14.40/month but I use it for unraring & was going to set up SABnzbd for Usenet downloads.
I’m in the middle of trying to get odrive setup but I’m really struggling.
EDIT: With regards to getting data from ACD to gdrive.
I signed up for cloudhq but it’s super slow
At this point, patience might be a good idea. Rclone may yet get resurrected for ACD and it’s not like Amazon is deleting anyone’s data.
It is slow to do the initial scan but I find once it has that bit out of the way, any time I add anything to Google Drive it is almost immediately copied to ACD.
Is anyone using an in house server with plexdrive? I’m having so many problems with VPS’s
[Unit]
[Service]
Type=simple
Restart=on-abort
[Install]
Thanks that worked
With Amazon disabling both Rclone and acd_cli (and pretty permanently it seems), I have gone ahead and updated the tutorial to include just one cloud service (Gsuite).
On the bright side, it’s now much easier to setup a VPS :slight_smile: Here it is for the ones who don’t see my signature: Tech Perplexed
It’s worth having a look at Plexdrive as an alternative for mounting. It’s a little more fiddly than rclone but I’ve had great results.
This is coming from someone who had to follow your guide to setup my VPS :slight_smile:
