Plex Connect On Deck
I got everything working correctly. Music, movies and TV Shows come up but On Deck doesn't seem to be working for TV Shows. It does show up fine in Movies. When I select TV Shows on Deck it hangs on accessing trailers.
On Deck for TV Shows works here. Try rebooting PMS and try again.
Restarted and still TV Shows On deck doesn't come up. Weird
Shut down PlexConnect
In Settings.cfg change loglevel = Normal to loglevel = High.
Delete your PlexConnect.log file.
Run PlexConnect again and navigate to the on Deck section.
Post the newly created PlexConnect.log file to pastebin.com and then post the pastbin link in this thread so I can have a look at it.
Here you go http://pastebin.com/6NvpJyNT
Your recently added section is empty..... What version of PMS are you running? If it's not the latest version 0.9.8.5.165 then please update and try again.
That was it. I had and older verison of plex. I thought I updated it but I guess the repository for linux isn't working so I installed the .deb package and it worked. On deck is there. Thanks roidy!!
Deleted found problem - same answer
