Plex crashes / hangs sitting idle or in use
Plex Version: Version 1.43.0.10492 updated to: Version 1.43.1.10576
Processor: 11th Gen Intel(R) Core™ i9-11900K @ 3.50GHz (3.50 GHz) Ram - 64.0 GB (63.8 GB usable) 64-bit operating system, x64-based processor, Windows 11 Pro, Ver. 25H2, OS Bld. 26200.8037
Local internal and USB drives 8TB and 16 TB
Plex Media Server Logs_2026-04-06_09-43-53 (2).zip (1.2 MB)
New log files added
Plex Media Server Logs_2026-04-08_11-49-16 (3).zip (2.0 MB)
PMS Plugin Logs.zip (224.4 KB)
Have you tried: https://github.com/ChuckPa/PlexDBRepair
Thank you for your quick reply and sorry for not responding sooner. Took me a little time to get to this. It appears the DBRepair seems to have solved my problem with PMS not responding, it also seems to have made Plex more responsive overall. Thank You again. May I ask if there was something in the log files or was this more of a generic reply to my issue?
EDIT: I may have spoken too soon after 3 hours uptime it stopped running. I will restart and leave running to see how it behaves over 24 hours. It has hung twice since my initial reply :frowning: .
Still having the same issue I need help. Is there something else I need to provide for direction to solve this issue?
Hello I have an update on my issue …. Now Solved. I had a conversation with Gemini AI and it had some very usefull suggestions on things to check. Long story short version…. I realized I had been testing my VPN and forgot to turn it back off. The Norton 360 VPN was blocking PMS web request causing PMS.exe to accumulate requests in the WaitChain as observed in the Resource Manager, when it reaches ~100 Threads PMS would hang. Turning OFF VPN solved the issue. I will look at setting up VPN Split Tunneling as a long term solution.
