Appreciate the additional info!
Thin Provisioning - something I wasn’t familiar with but sounds pretty cool/will look into.
I think I may end up changing over to a directory style docker setup. Shakes fist at docker
My PMS main DB/all that good stuff resides on it’s own dedicated 2TB SSD while appdata/cache (in my case where) /config live on their own 4TB SSD - 200GB reserved for docker image.
However now with the handy script + the possible larger size via directory it put my fears to bed a bit of filling up the cache drive (4TB SSD) entirely.
(CreditsDetection) Retry detection only a limited amount of times on failures (PM-1093)
Wondering if this might be a fix for the issue I’ve had/needed the script for cleanup?
I am going to be updating to the beta for the Push Notifications fix but will also plan on disabling script and allowing to run like normal to see if the issue of .tmp fill up occurs.
(Push Notifications) Used expensive DB query during playback progress notifications (PM-1166)
