Plex Desktop player wants to stream over bad connection instead of using downloaded media
Server Version#: 1.40.3.8555
Player Version#: 1.95.3.175-dd94cbd1
I often travel to places with rather terrible internet connections. So I try to download media locally using the Plex player download button and typically it sync’d over night
The media plays without any issues whenever I have no connection (no internet at all) or when the wifi is disabled. However, if there is a connection, it tries to stream off my Plex server which obviously becomes a choppy stutter-fest.
Any idea how I can resolve this without disabling my wifi?
I’m in a similar boat. Are you playing the shows from the home/dashboard page? If I’m connected and play a show/film that I have downloaded from anywhere other than the downloads page, it tries to stream it (and that’s a terrible experience). Only if I specifically go into downloads and play from there will it use the local file.
This is unhelpful functionality, but (for now) seems to be how it works.
( https://forums.plex.tv/t/play-downloaded-media-before-streaming/881662 )
This is exactly what I am doing. The work around you mentioned, playing from the Download section, works perfectly.
I guess we both assumed that the Plex client would have been smart enough to detect we have a local copy and use that instead
Anyone that has the same issue, please consider voting for the feature request below:
