Plex died sometimes
Server Version#: 1.16.2.1297 & 1.16.1.1291
Hi, I have some trouble with my Plex. I have a Synology (1.16.2.1297) and an Ubuntu (18.04.2 LTS) Plex (1.16.1.1291) server running. Both of them having the same problem. If I start a search for new media and go at the same time the searc is running to the new activity dashboard, the Plex server died.
Is there a way to disable the new dashboard (temporary?) and get the old one back? In general the new dashboard activity is great, but for my not stable in my environment. Both machines having that problem. Have somebody an idea.
If you can provide the log files, captured immediately after recovering from it restarting, that would be great. We can look and see what happened.
What sort of problem are you having? Maybe it’s something they overlooked or a bug in your usage case ?
As for changing the dashboard UI? I’m afraid not. This is what Engineering has decided.
its not so easy to tune a synology. But there are some points to tune up ubuntu. So I try something and it looks like it helps.
Right now I found some warning messages inside the console and hope somebody can tell me a little bit more about that. I goole it but don’t find anything about.
MyPlex: Invalid response when mapping state (code=429):
MyPlex: failed to update country code, response returned code 429
PubSub: Received notifyConnectivity event with unknown async identifier (xxxxx) (I made an xxx instead of real number.
The above messages are all warnings. No errors…:slight_smile:
I get every second 2 or 3 from this one “MyPlex: Invalid response when mapping state (code=429):”. So if I can fix that, this will be great. I don’t know what I can do here.
Logs please?
Here it is…:slight_smile:Plex Media Server Logs_2019-07-16_16-44-19.zip (5.0 MB)
Thank you for the logs.
I see you used Plex a lot today. In the logs you sent me, I am only seeing an approximate 45 minute window of elapsed time.
Did you restart PMS at this time or earlier?
Jul 16, 2019 15:33:22.217 [0x7fc2edad8700] INFO - Plex Media Server v1.16.2.1297-4b7ace214 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT 02:00
Jul 16, 2019 15:33:22.217 [0x7fc2edad8700] INFO - Linux version: 18.04.2 LTS (Bionic Beaver), language: de-DE
Jul 16, 2019 15:33:22.217 [0x7fc2edad8700] INFO - Processor        Intel(R) Core(TM) i7-2600S CPU @ 2.80GHz
If you restarted earlier, it is most beneficial if you capture the log files after restarting and before they are dropped. PMS only keeps 26 MB of log files (about an hour of usage).
Thanks to take a look. I will do that, but I need time. Will come back later this week to you.
Thanks in advance to take a look
