Plex doens't find anything inside folders
Server Version#: 4.29.0
Hello,
I have a problem with plex since las week. Plex worked perfectly but one day I had a crush with I/O filesystem HDD. It was a system problem, not a physical problem so I could resolve the problem.
After this, I reinstall plex and everything goes fine, except that if I put episodes inside TVSHows library plex doesn’t find anything. Instead, if the same files I copy without the folder Plex goes well. Of course I review the permissions folder, but this is not the problem.
I have another music library with folders in another HDD and everything goes well. I tried to copy the episodes inside this folder structure and created another TvShows but I had the same problem, plex doesn’t find the episodes inside folder.
I checked the logs and I don’t find anything clear, the only part is this, but I don’t know really if it’s a problem.
Please anyone can help me to find the problem?
Rubén
Check your file names.
TV show file names must use sXXeYY naming.
For example:
/Evil (2019)/Season 01/Evil (2019) - s01e01 - Genesis 1.mkv
Hello,
Thanks for the answer. This is not the problem because, as I told before, if I copy the exact file outside the folder, Plex find them. And of course the name of the files are correct in the way that you told me.
I think that there is a problem with the folder and maybe database who thinks that anything change when I put the files inside the folder.
Have this sense?
Your log file snippet does not show the full file name, but it shows it is not named according to Plex recommendations.
/Evil (2019)/Season 01/Evil - Temporada 1 [HDTV 720p].....
Recommendations:
  1. Make sure your files follow Plex naming recommendations.
    Naming and Organizing Your TV Show Files
  2. Plex Dance the show after renaming and reorganizing
If that does not work:
  1. Restart Plex Media Server
  2. Wait two minutes for Plex to fully start
  3. Scan the library containing the TV show
  4. Pull log files (Settings → Troubleshooting) and attach the entire ZIP file to the thread.
I had a similar problem on two different Plex Media Servers on different Operating Systems and this is what fixed my problem on both servers.
The first thing I did was change the Agent from “Plex TV Series” to “TheTVDB”.
This change gave me the option to “Upgrade Library”… Once I selected to upgrade the library, all missing folders and episodes appeared.
Good afternoon,
I did both recommendations, and finally it works, I think that the real solution is the name of the files. In my case, I hadn’t the name in this format " - s01e01 - " I hadn’t the spaces between the “-” so Plex didn’t work. Certainly, Plex is sooooo strictly with the names.
So thank you to everyone to help me.
Thanks a lot
Rubén
