Plex DVR Marching Error
I’m recording Charlie’s Angels (1976) from ME.TV. The guide shows and Plex DVR correctly stores the video’s in a Charlie’s Angels (1976) folder, but when it shows up in the library, it matches to Charlie’s Angels (2001) instead.
If you click on the Show in the Library and then the More button at the top does the Fix Match not allow you to correct it?
I know I can fix the match, but shouldn’t the DVR guide data and the default scraper should not require this step.
