Plex DVR not recording or cuts off recordings early
Lately I have had issues with Plex not recording or stopping the recording early. At first I this was possibly due to a poor tv signal, but while I was watching live tv via the homerunhd spoon my apple tv I got a notification on my phone that the same show had finished recording km plex. The show was only half over. There was no signal issue at all. This need a fix so plex records what ever is presented to it. So if it a poor signal than the recording maybe jumbled. If there is no signal than show a blank screen. I know other dvr services do this.
Would you please post debug level server logs covering the time of a failed recording? Then we may be able to see additional detail to understand what is causing the failure.
Plex Media Server Logs_2023-03-29_19-24-29.zip (2.3 MB)
It just happened again.
I see a lot of slow database queries in your logs, and also messages that Plex is having problems communicating with your HDHR tuner and is marking it as dead. I don’t know that this is what is causing your issue, but first I’d suggest optimizing your database:
Go into Plex Web, then Settings (the wrench in the upper right). On the left scroll down and click on “Troubleshooting” and then click on the “Optimize Database” button.
I see where your transcode service failed to respond in time, resulting in a recording failure:
Mar 22, 2023 21:01:10.486 [0x700000f6b000] ERROR - [Req#34bbc/Transcode/d93bd96f-2144-4e78-9773-3dc7ed32e844/29c7a83c-3450-4e4f-9402-f6e11b1b71a7] http://192.168.50.147:5004/auto/v25.1: Server returned 5XX Server Error reply
Mar 22, 2023 21:01:10.489 [0x700000cdc000] ERROR - [Grabber/53d660e6fbfcb58f0aaedfc1c70a082c1fed7bdc] Failed to start session.
Mar 22, 2023 21:01:10.490 [0x700000cdc000] ERROR - [Grabber/53d660e6fbfcb58f0aaedfc1c70a082c1fed7bdc] Recorder: Unable to create transcode session or session failed to start.
Mar 22, 2023 21:01:10.490 [0x700000cdc000] ERROR - [Grabber/53d660e6fbfcb58f0aaedfc1c70a082c1fed7bdc] Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Are you experiencing any general slow performance on your plex server computer?
You may not be aware but this is the last Plex version you will be able to run:
  • (MacOS) This is the last release to support MacOS 10.11-10.12
I am surprised the Core 2 Duo was even able to work with Live TV & DVR at all. As Plex expands the its features they have required more an more CPU resources.
