Server Version#: 1.25.6.5577
Player Version#: iOS 7.29
Problem description
Download a TV play to IOS mobile phone by using the attached figure. The following problems are found:
After the download starts, the same episode is downloaded in an infinite loop. Even if it has been downloaded to the mobile phone, it is still downloaded in an infinite loop.
When the infinite cyclic download occurs, even if the download item is cancelled from the mobile client, the mobile client will still download from the server endlessly. The cyclic download can only be stopped by forcibly ending the mobile client.
I use Chinese - English translation. If I donāt describe it clearly, please forgive me Please also find friends with similar problems to help supplement. thank you
May 18 supplementary update
I reported on 2022-2-27 that there is a loop download problem when PLEX downloads multiple items. In addition to this problem, even if the music album has been downloaded, the downloaded content will be automatically deleted after a period of time, that is It is said that the paid download function has serious bugs and cannot be used at all.
Many users have confirmed the same problem, We have waited patiently for several months and have not solved it, and we have not given a solution time.
After the user pays, Plex is responsible for ensuring that the function is available, which is the most basic business contract.
I want a detailed response from plex, why hasnāt it been resolved for so long?
A lot of user feedback, they encountered the same problem.
I was having this issue in another thread, and we figured out that it was because I have the Seasons option set to āhideā for my TV library.
If you change this to āShow,ā you have to do the following:
Make sure the library is set to āShowā
Make sure the individual shows within the library are set to āShowā (changing the library does NOT change all the shows ā You have to edit the show and the option is under āAdvancedā)
Delete all your downloads and start clean
When I did all of this, my shows stopped the infinite cycling. Apparently this was a bug in the past that they thought they had fixed, so theyāre readdressing it.
Iām not seeing this looping in your logs. I do see where it is having trouble accessing your server. The app does check for changes to the watched status so itās possible itās having issues with your server so itās in a loop doing this check. Check your server, does it show itās downloading the file?
I found that the problem of infinite loop download also occurred in the music albums
Your logs show it is getting back a 404 error from your server when it tries to get the metadata for that album and tracks to save locally. Can you get me the XML info for the first track in that album?
In the first half of the movie, the client download media library shows that 18 episodes have been downloaded, but the server panel shows that 18 episodes are still being downloaded repeatedly
In the second half of the movie, the progress bar on the server panel shows that after 20 episodes are downloaded, another 20 episodes are downloaded circularly 2022-03-01 20.54.14.mp4.zip (16.1 MB)
video 2
After the problem of cyclic download occurs, the download item is manually cancelled. At this time, there is no item downloading on the client, but it can be seen from the video that the client is still downloading, and the download speed is 8MB / s. After the forced end of the client, open it again, and the previously cancelled item is automatically restored, and the download is still continuing 2022-03-01 20.58.50.mp4.zip (6.8 MB)
Could you PM me your PMS database? I think it might have something to do with the Chinese characters. Iād like to check how these are being saved in your database to make sure they are using the correct encoding.
Has any progress been made on this issue? While Iām not seeing a true infinite loop in downloads - I am constantly seeing downloads repeatedly repeat themselves if I queue more than one thing to download.
Just tried this a few times where I started from nothing to be downloaded and then queued 4 items to download - then watched the download status in the app and dashboard simultaneously. In both attempts the first item I queued downloaded just once, the 2nd downloaded 2 times, the 3rd 4 times, and the 4th 5 times (not sure why it skipped 3 times).
Oddly, if I had a bunch already queued and force killed and restarted the app (say because you donāt want it to download the same bloody thing yet again) it seemed to follow the same pattern - just starting at the downloading 2 step (so download the first thing still in the queue twice, then next 4 times, next 5 times).
Thank you for your voice.
If you have the same problem, please send out our voice. I hope the official will take your actions to respond to usersā concerns and solve this terrible download problem as soon as possible. @anon18523487
I have the same issue with my Music library where itās constantly removing previously downloaded items and re-downloads them. This makes the Downloads feature completely unusable since it is entirely random which Albums have finished downloading when I leave my home. The Sync feature worked for me for many years and Iād really just like to go back to that, is that possible?
There is a serious problem with the download function and it cannot be used. I reported this problem on the forum, but more than ten days have passed. Although I ask the situation on the forum every day, I have not received a response.
There is really no way, please help to wake up the sleeping administrator together, and ask them to respond to the problems encountered by users. Thank you for your help.
Just found my way to this thread because my dad told me that for the last week he has been getting ātoo many streams in useā error. He isnāt actually playing anything, but it occurred to me he is the only user I allow downloads for, and he has been using the feature lately.
He just called me finally after a week saying this was going on and I have absolutely not a single person streaming right now even though he was getting the error. There is NO REASON why he should be seeing ātoo many streams in useā I saw Plex had an update so I let it apply which restarted my server and itās working for him again now. I disabled his downloads.
My guess is that this bug, whatever it is, was causing a traffic jam with the downloads feature for his user account. Whatever gets locked up probably reporting to the server and causing the max stream amounts to read over limit.
Not grabbing any logs because I can already tell Plex is in IDGAF mode for this one. Hopefully my post here serves as helpful for someone else having this issue and going WTF?
Looks like everyone should be disabling and not using downloads going forward because they seem to be driving it into the same ditch they drove Plex Sync into.
Download a 325MB music album with an average download speed of 3MB +. The download that should be completed in less than two minutes actually took more than an hour
Why download so long? Not that the Internet speed is not fast enough, but that it is constantly downloading the same music This problem can be seen in the following video.
