Armv7a working for me as well.
I confirm : working fine with version arm7 and new player enabled.
Thanks for your well appreciated help
I have two Mi box S-es as well and plex stopped working on both since the latest System update from a few days ago. If I disable the new player the old player works with a few videos but most donāt play.
Hopefully a fix is coming
Work for me !
Thew apk is not available any more
It will be probably merged into the next (beta) release, so you need to be a bit patient for the release.
Hello,
I have the same problem. Exist any conclusion?
thanks in advance
I am having the same problem as everyone in the thread. Must use old player for Plex to work. Server is working on all other devices besides mibox s.
Is this a client or server issue? My guess is client. I am running Android client v8.0.1.17410 (0cf80098) on Andriod TV v8 on a MIBOX 3 as well as the same app version on my Andriod 9 phone. Get same errors as previously posted. I can gather logs if they will help.
Is there an ETA for a fix? Rolling back to old player does not resolve.
Can somebody please share the APK posted above here, it has been removed and I really want to try it!
There is a new beta release. Take that
Where would I find that? The downloads section on the Plex site just takes me to the Play Store which does not contain the beta release?
can someone please send me a link for this
arm7
PlexForAndroid-8.1.0.17362-1ddb3df9-Armv7aGooglePlayStdExo.apk
i need to use the new player on my mi box so i can expand the video on my projector
No need, take the new beta release it is linked DIRECTLY before your post.
getting āapp not installedā on mi box s. is there an arm7 version
thanks i found the arm7 version, working now
I can confirm now the newest beta works.
Thatās not actually the solution, by the way (disabling experimental video player).
Disabling it, I still have to shuffle between Convert Automatically and Direct Play before a video will even load on the original/normal video player - and thereās no logic behind it because you constantly have to toggle it onto the opposite of what you have set, for every new video you openā¦
With experimental, the video doesnāt load no matter what.
The best workaround so far as been disabling automatic refresh rate.
But, thatās a workaround and not a solution as it removes functionality to fix a bug.
The problems already been fixed in beta.
