I have the Popcorn Hour C-300 also with Plex 1.0.9 and I have the same problem but only since the last Plex Server update. I actually restored a Windows image from 3 weeks ago and the Popcorn Plex client works perfectly. Then I updated the server and the client couldn’t connect anymore.
I was looking for the previous Plex server installation but I cannot find anything, which is trustful enough.
Where on the Plex site can I find at least the previous server installation???
Hi Eastpak1984,
Occasionally you will find older versions on the internet but I would be careful with those sites. I have a Windows PC as my server and all older Plex server versions are kept in %LOCALAPPDATA%\Plex Media Server\Updates, about 95MB each. I cannot update my Popcorn Hour as there is no newer version available - that’s at least what the ‘Update’ section says. So I think we have to stick with 1.0.9 for the moment. I don’t know what’s easier: ask Popcorn hour client guys to update or ask the Plex server guys to make it backward compatible (as it should be anyway).
Go to your Plex server settings. Click “Server” at the top then “Network” on the left. Now hit the “Show Advanced” button. Add the IP address of your Popcorn Hour to the allowed without authorization box. Save changes and then try to reconnect the Popcorn Hour client.
hi I have this problem on my popcorn hour V10 now I saw this after I installed plexmnt app which at the beginning of the app install, ask you for your plex servers ip address and port so I type in the plex web ip address and then I included this adding the popcorn ip into the plex settings, but still no luck how can you go back on the popcorn to change the app ip as I tried uninstalling the app and reinstalling but that part of the app settings no longer comes up goes straight to displaying blank movies
