I’m having an issue where every now and then while I’m streaming Plex it will stop and start buffering and hang there forever. If I’m using Chromecast with Google TV (whether casted or through the native app), I’ll have to totally restart the Chromecast to fix it. It also happens when playing back through the web app but there I can back out and restart playback and it’s fine.
This seems to usually happen in the last half to last third of the runtime of the media file. For some TV shows it seems to happen within the last 30 seconds
I run Plex through a Docker on a Open Media Vault Linux media server.
I’ve had this issue for a few months now probably. Any help is appreciated.
Had plex infinite buffer yet again. Was playing back on chromecast so I caught the chromecast logs this time. Here they are, I attached them along with the server log. The problem happened somewhere around 22:05-22:15 in the logs logs.zip (828.5 KB)
Looks like it might be something with transcoding?
Sometimes my Roku client will lose connection to the Plex server while watching Live TV and it will sit there buffering for a few minutes before dying. I’m also using podman on CentOS. Seems similar to what you’re saying.
This happened yet again, here are the logs. Occurred somewhere around 12:30-12:50pm 9/1 in the logs logs.zip (718.4 KB)
Any way to tag plex support in these posts?
Had the hang again. I was playing through plex web player in chrome this time. I had direct play and direct stream disabled so I guess those can be ruled out.
Having a similar issue with my Google TV too. Always have to back out and replay the file. Occurs roughly 10-20 min of start of playback, so maybe a transcode buffer issue? I’m playing it off-site.
I figured it out for my situation. I have an USB C hub connected with an Ethernet connection. I just unplugged the Ethernet and it works without infinite buffering. Seems like the connection is getting dropped for some reason if you’re using Ethernet, which is pretty weird. I have it connected to make streaming games work, but seems like this is my workaround for Plex.
