ERROR - SSDP: Error parsing device schema for http://192.168.x.xx:2869/upnphost/udhisapi.dll?
WARN - [Chromecast] Did not move header "accept" to query string. This can result in an unnecessary OPTIONS preflight request.
ERROR XML: Entity: line 1:
ERROR XML: parser
ERROR XML: error :
ERROR XML: Start tag expected, '<' not found
ERROR XML: status=ok
ERROR XML: ^
ERROR Error parsing content.
ERROR Error parsing XML: Error parsing file.
For clarification, in the logs there are mainly 4 IPs for which I am getting SSDP errors: my laptop, google chromecast 4k and chromecast with google TV.
Check your media hard drive. If nothing has changed then your HD may be failing. If the server has issues reading the data off of the drive it would cause this issue.
Looks like your server may be having problems finding devices on your network. Two things I would suggest.
Make sure your default route on your server points to your router - if it doesn’t your box may not find the routing table.
Second is create a host file on your sever. You need the network names of all your Plex playing devices and their IP address. You will want to move to static addresses for this to be a permanent solution.
