Plex is not correctly matching TV series, no matter what I do
Server Version#: 1.41.5.9522
Player Version#: 1.108.1 Plex for Windows x64
I have the following media that I am trying to organize in my TV Shows library:
Battlestar Galactica (1978) series
Battlestar Galactica (2003) mini-series
Battlestar Galactica (2004) series
Currently Plex is grouping all media under the 1978 Battlestar Galactica series, and not showing the 2003 mini-series two-parter, nor Season 1 of the 2004 series.
I asked for help on Reddit and it was suggested that adding the IMDb ID would resolve this (it didn’t). I would not be opposed to creating custom metadata to force Plex to properly split these into 3 different “shows”, but I’d rather not go that way if I don’t have to do so.
Plex is also incorrectly putting a date of 2003 on the revival series, when in fact it aired in 2004. The mini-series from 2003 acted as a backdoor pilot for the new series.
If someone could give me a hand figuring this out, that’d be great. I can supply whatever data you require.
I don’t think Plex TV series agent will consider IMDb references – only those from TMDb and TheTVDb.
Would you mind sharing how those shows are currently organized inside your library folder (incl. episode names)?
Of course, currently:
/plexdata/television/Battlestar Galactica (1978)/Season 01/Battlestar Galactica (1978) - s01eXX.mkv (episodes 1-34)
/plexdata/television/Battlestar Galactica (2003)/Season 01/Battlestar Galactica (2003) - s01e01.mkv, s01e02.mkv
/plexdata/television/Battlestar Galactica (2004)/Season 01, Season 02, etc. for all four seasons, and named the same as above - Battlestar Galactica (2004) - s0XeXX.mkv
I take it, your library is pointing at /plexdata/television?
In that case, the structure looks ok.
If Plex is giving you a hard time, you can indeed include a matching hint in the folder names, e.g.
  • plexdata/television/Battlestar Galactica (1978) {tvdb-71173}/...
  • plexdata/television/Battlestar Galactica (2003) {tmdb-71365}/...
  • plexdata/television/Battlestar Galactica (2004) {tmdb-1972}/...
If you want to go with TheTVDb episode ordering, keep in mind that they’re treating the Mini Series as extras of the main show (s00e01 and s00e02)!
This did help to fix it.
Is there a guide somewhere on writing custom metadata to force Plex to display certain media in the manner in which I want it displayed? I thought I parsed through the documentation, but maybe I’ve missed it.
You can use a matching hint file to point Plex to how to match those files.
https://support.plex.tv/articles/plexmatch/
Plex had announced they’re working to add a new agent framework that’ll also allow adding local metadata (e.g. nfo files) – though that’s still on their roadmap and not yet released.
As of today you’re best sticking with the available episode orders currently supported by Plex:
  • TMDb (aired order)
  • TheTVDb (all available orders)
