Server Version#: 1.19.5.3035
Player Version#: 4.38.1
See attached XML and logs, it lists a reference to the same file twice. This shows up in the UI as a (2) as if there are multiple playback options.
Plex Logs.zip (8.5 MB)
Hey, I included the XML. Check it out, itâs literally the same file referenced twice.
Shouldnât #3 be âEmpty Trashâ?
Is Empty Trash not needed as part of the Plex Dance in general, or just for @ephetersonâs specific problem?
Can you explain more about what has changed? Thatâs going to be important for a lot of people.
If I donât Empty Trash, the library items remain, and Clean Bundles doesnât have any effect.
Is Optimize Database now doing other things automatically? I didnât think its function was required for the Plex Dance.
/confused.
@trumpy81 âŠ
If Optimize Database IS doing things, like Empty Trash automatically, thatâs not gonna be popular with people like me who do not want the trash emptied automatically. We set that option for valid reasons.
Combine that (possible change) with the Scheduled tasks, which include Optimize Database every week, and I could end up with a lot of deleted and newly added items I donât want.
The tips and tricks page for the Plex Dance doesnât show a change in the procedure.
Thank you for the clarification. I had the same alarm as @leelynds.
@trumpy81 I donât think that workaround is sufficient (havenât tried it) because this keeps happening on new entries. Not all, but many.
We need to find a solution that prevents it from occurring for new downloads.
Are you downloading straight to the Library directory, or moving the file after it has completed?
Interesting idea, I do have that library scanning the download directory, and the final directory (to handle cases where the move doesnât happen correctly). This may have recently started leading to this bug, although itâs not showing paths from both directories it may have a bug updating and removing an entry if two are identical.
Iâll try removing the download folder from the library to see if this stops, but this is a recent regression in Plex server (my settings havenât changed in at least a year).
Itâs not a âregressionâ
Itâs a miracle this hasnât happened up to now.
Donât call Plex.
Call:
Ripley
or
The Vatican
'Cause what we have right here is Believe or Not - or a prelude to The Second Coming.
Pick one.
My MCEBuddy monitors download areas 'cause itâs smart enough to sit quietly until they actually arrive - then it renames them, sucks the 608s out of 'em (if present), turns 'em into srt files - names them too - and puts them in a Valid Library Type in the Plexiverse.
Plex isnât smart enough to do that.
Donât let it try.
Hey @JuiceWSA, I respectfully disagree that Plex isnât smart enough to handle this, itâs clearly a bug if Plex references the same file twice on the same item, and by definition this is a regression if it never occurred before.
I also use Sonarr to rename/move/clean downloads and have never had issues before.
To be clear itâs referencing identical file paths, not the download directory and the final directory, and the file isnât in two places at once except for maybe at the instant of the move (if it does safe move via copy/delete).
@trumpy81 I think youâre confusing the issue, at the time the download is occurring the final extension isnât appended until itâs complete. Plex has never accidentally imported an incomplete download.
I donât see how any of these steps make it less of an issue that Plex has changed behavior to allow multiple instances of identical paths on library items.
I do appreciate the help with suggestions (weâll have to see if this indexing change even works), but Plex should collapse identical file entries for an item into one instead of maintaining two. This only started days ago, itâs likely a change in the last server update or one before.
https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
Copy In Progress
Another thing that can cause issues is if youâre copying content to the drive and directly into the content location. In such a situation, when the content copy first starts, the Plex Media Server scanner can note the change and then wait 60s. If nothing else has changed at that point, it will perform a library scan.
However, if your content is copying and takes longer than a minute, then itâs possible for a situation to occur where the scan occurs before the copy finishes (and thus the content is not ready/available for the scan). Subsequent scans would not actually look in the directory because it doesnât appear that the directory changed since the previous scan.
The easy solution for that is to not copy the content directly to your content location on the drive. Instead, copy it to another, temporary or âstagingâ location/folder on the drive first and then when the copying is completed, move it into the standard content location.
Thems da rules - ignore them at your own peril.
I agree the behavior youâre seeing is weird. It shouldnât show up in Plex with the same path twice, even if youâre doing something else weird.
From a filesystem semantics perspective, thatâs actually less âsafeâ. A single-step âatomicâ move is instantaneous and thus âsaferâ.
With a âmoveâ, the file will be 100% there before Plex is notified to scan. Thatâs ideal because when Plex goes to scan all of the files will be there, wonât be locked, can be read and probed, etc.
With a âcopyâ, Plex might be notified before the full file is available, possibly while itâs still locked for the copy, etc. Plex might not be able to scan the file. It might get notified again when the copy completes.
(Iâm not sure how Plex interacts with the filesystem change APIs. It might take steps to avoid this.)
Edit: HAH, I was just going to say ⊠I think thereâs a help doc ⊠which also answers my question about how Plex mitigates potential issues.
Itâs definitely not intuitive.
@trumpy81, @JuiceWSA and @Volts, I do appreciate the extra information, but I persist that this is a bug and regression.
The solution @JuiceWSA shared is for if Iâm having issues with content not being found, which is not my problem. To solve the problem that article mentions, another library scan would fix it, but in my case subsequent scans donât fix it.
Itâs not a big deal if the recommendation resolves my issue (and honestly isnât a big deal in any case), but this is an easy bug to fix and was only recently added.
I agree that it seems like a bug for Plex to create multiple media file entries with the same path.
In the example you gave they have 100% the same path. Theyâre both marked available.
Even if you were doing âbadâ things with files, or kicking puppies, I canât think of a reason that Plex should be doing that.
I can think of reasons that it MIGHT do that, but I agree they seem like bugs.
If you can make it reproducible, maybe the Plex folks would be interested.
Obviously if everything is working when following the supported processes, thatâs great news.
Thanks for seeing my side, @Volts. Itâs very reproducible, but I may never see it again now that I removed the other directory. Iâd be happy to add it back if Plex devs want to get more info or logs.
Iâll try and remember to chime back in here if removing the second directory worked, thanks everyone!
Hey all, so unfortunately itâs still happening sometimes even with the downloads folder not being indexed.
I wonder if itâs worth trying the latest (1.20.0.3125) PMS, and either upgrading your library or creating a test library. That has big changes to Scanner & Agent, and it would probably be easiest to get attention for the ânewâ version too.
Are the download and storage locations on the same disk? When the download is complete, is the file âinstantly movedâ or does it take a while (more than a minute?) to copy between locations?
If current PMS doesnât solve it, itâs probably worth catching Plex logs of this happening.
I updated to the latest automatically last night, so weâll see. About the copy vs. move, from what I read if Sonarr sees that the download and final directories are in the same filesystem, itâll do a move instead of a copy. Iâve verified Sonarr sees the whole filesystem, so potentially, but Iâm not sure how to verify in the logs even with debug/trace enabled.
