Plex keeps crashing on QNAP
Hi all,
Is anyone having an issue whereby Plex keeps crashing (which in turn causes the NAS to crash too)?
I am running Plex on a QNAP TS-453D (up to date) and I have been having this issue with the last 2-3 updates, so end up going back to version 1.40.2.8312 as this is the last stable version!
This seems to happen mostly when someone is transcoding, but something happens when there is no transcoding too.
I have the logs from the last crash, so happy to share this.
Thanks in advance
If you have DEBUG logging enabled ,
Do you have the ZIP log file which you downloaded right after restarting PMS ?
If not, would you mind capturing one of those and then attaching that ZIP?
This allows us to see what it was doing right before it crashed and how it recovered.
Hi @ChuckPa, I do indeed, I will send PM the logs to you now.
Nevermind, it seems you are not accepting PMs @ChuckPa. Is there another way to send you the logs? The file is 11Mb, so I don’t think it will even work via PM?
