Before this update Plex worked flawlessly for me. It now dims after a few mins before finally going black while watching a video. You can still hear sound while the screen is black. I have uninstalled & reinstalled the app which did not fix it. I have an xbox with kinect hooked up so it does see that i am there watching a video. I did not have this issue before the update so something is wrong.
Can anyone help or is this a known issue which will hopefully be patched soon??!?!
Thanks!
My wife told me about something like this as well, she was watching a movie and it would start to dim while watching it, i haven't personally seen it yet, but it seems others are having the same problem.
Thanks for responding. Reading another post I was able to find the fix, and it definitely works fine now afterwards.
Perform a hard reset on the Xbox by holding power button for about 20 seconds. You will know it worked when the light on on power brick goes from white to orange.
Plex is now working perfectly again. Very odd issue.
If you see this issue again, could you please post the exact steps on how you started Plex and the video playback? Whether you're using the Kinect, or bringing up the video controls at any time etc.
I'm sorry if you're having issues with it. Once we can reproduce the issue here we can get it fixed.
The player dims to about 50% brightness after 60 seconds or so.
After a couple of minutes the picture is gone (black screen).
No controls (play, pause, settings, etc.) change this behavior; the only way to get the picture back is to use the XBOX button on a controller or remote to switch into the main menu and go back into the PLEX client.
This is a new behavior; PLEX worked flawlessly beforehand.
Mine dims to black but I can wake it up, so not seeing these problems.
I do feel it's a little obnoxiously over zealous though in its dimming - would like an option to slow the process, or even disable it. Even better, implement the fan art screensaver?
The suggested restart of the xbox has not made any change for me.
It will take about 10 minutes for the first dim to occur, I can then hit a direction key on my remote and it will go back to normal brightness, after the first time, it will then dim every 3-5 minutes. It is not dimming after the same interval each time for me.
I dont know if this was said before so i go ahead anyway,
Are you guys using a controller or a remot to control plex and the xbox?
I found out that if i plug in my Controller into the xbox's USB port it keeps the screen from dimming.
The hard reset worked for a few days now out of nowhere it is back to dimming again. It’s driving me crazy. This app is completely unusable now which is a shame because it was fine before this update. Has the developer said anything about this or acknowledged it anywhere???
The hard reset worked for a few days now out of nowhere it is back to dimming again. It's driving me crazy. This app is completely unusable now which is a shame because it was fine before this update. Has the developer said anything about this or acknowledged it anywhere???
