Plex Keeps Losing Connection to Server
Server Version#: 1.18.5.2309
Synology DS918+
Recently my I’ve been losing connection to my server. I can hop into DSM, and stop and restart Plex, and it works again. Seems to happen about once a day.
I can’t pinpoint the timing of the issue starting to this, but I did upgrade my RAM from the OEM 4gb to 2x Crucial 4gb set here.
I plan to pop those out, and throw in the OEM 4gb stick tonight when I get home, but figured I’d post here, and see if anyone had any thoughts on what could be happening.
Never downloaded logs before - so hopefully I did that correctly.
Plex Media Server Logs_2020-02-07_07-12-49.zip (4.8 MB)
Any ideas on what could be happening here?
I see that many folks having issues with the last couple versions. Before I downgrade to a previous version, does anyone have anything I could try first?
I apologize for the delay. I’ve been “eyeballs-deep” in rebuilding my workstation from scratch.
bufferedTime=56&duration=2494016&key=%2Flibrary%2Fmetadata%2F60069&location=lan&playQueueItemID=183371&playbackTime=764154&ratingKey=60069&state=playing&time=764134 (12 live) TLS GZIP 12ms 771 bytes (pipelined: 200)
Feb 07, 2020 07:05:41.159 [0x7f5bb7d11700] ERROR - Error issuing curl_easy_perform(handle): 28
Feb 07, 2020 07:05:41.159 [0x7f5bb7d11700] DEBUG - HTTP simulating 408 after curl timeout
Feb 07, 2020 07:05:41.159 [0x7f5bb7d11700] ERROR - SSDP: Error parsing device schema for http://192.168.7.1:1900/igd.xml
You have a device which is advertising itself as a gateway. You should consider turning that off if possible.
I see where “Other Room” disconnected. Is this on WiFi ?
It’s an AppleTV 4k connected w/ ethernet.
May I ask the network topology?
Everything wired? Any Proxies involved?
ATT Modem to Eero Router to TPLink Switch - several AppleTV devices CAT6, some wireless. Shut down again, attaching new logs.Plex Media Server Logs_2020-02-09_19-03-34.zip (4.6 MB)
