Plex Live TV from HDHomeRun FLEX4K fails to sustain playback on macOS 26 beta 6
Server Version#:1.42.1.10060
Player Version#: also attempted playing on iOS (Plex for iOS) Client Version 2025.22.0 (1195)
Tuner Make/Model:HD Homerun Flex 4K
Guide/Lineup name: using Plex default
Using XMLTV?: No
Channel number/Name: any
Summary
On macOS 26 beta developer build 6, Plex Media Server successfully detects and tunes my HDHomeRun FLEX4K tuner but fails to sustain playback. Streams either do not start or play for about one second before showing “Playback Error. This live TV session has ended.”
The same hardware, network, and Plex configuration works flawlessly on macOS 18.6. The issue appears specific to Plex’s handling of the MPEG-TS stream under macOS 26 beta.
Environment
  • Plex Media Server Version: Latest stable build (no beta available at time of testing)
  • macOS Version: 26 beta developer build 6
  • Mac Hardware: Mac Mini M4, 24 GB RAM
  • Tuner: HDHomeRun FLEX4K (firmware up to date)
  • Network: Gigabit Ethernet, firewall disabled
  • Other Test System: Mac Mini M1, macOS 18.6 → works fine with same Plex version
  • Clients Tested: Plex Web, Plex Apple TV app, Plex iOS app — same result
Steps to Reproduce
  1. Connect HDHomeRun FLEX4K to network and verify in HDHomeRun Mac app (tunes channels successfully).
  2. Install Plex Media Server on macOS 26 beta 6 (M4 Mac Mini).
  3. In Plex Web App, add HDHomeRun FLEX4K manually via IP or auto-discovery.
  4. Attempt to watch any live TV channel via Plex (direct play or transcoding).
  5. Observe that the stream either fails to start or plays for ~1 second before error appears.
Expected Result
Live TV stream from HDHomeRun should play continuously in Plex as it does in:
  • Plex on macOS 18.6
  • HDHomeRun Mac app on macOS 26 beta
  • VLC on macOS 26 beta
Actual Result
Playback ends within ~1 second with: Playback Error
Additional Notes
  • Lowering streaming quality and disabling transcoding in Plex has no effect.
  • HDHomeRun Mac app on same macOS 26 beta machine streams without interruption.
  • VLC successfully plays direct stream via http://[HDHR-IP]:5004/auto/vXX.
  • Firewall is off; local network permission for Plex is granted.
  • On macOS 18.6 with identical hardware/network setup, Plex Live TV works without issue.
  • dns-sd -B _hdhomerun._tcp returns “STARTING” but no broadcast results, though Plex can find tuner after manual IP entry.
Plex Media Server Logs_2025-08-12_14-37-07.zip (2.9 MB)
Plex Media Server Databases_2025-08-12_14-37-55.zip (1.5 MB)
