I have a problem with some Live TV channels. Server Media Server () runs on Windows Server 2016 with Intel Pentium G4600 and the Live TV Tuner is a VU+ UNO 4K SE (DVB-S2) with OpenATV 6.1 and HRTunerProxy. The channels are decrypted with OSCam. All my german HD+ channels working fine, but some german Sky channels are not working. The channels are:
Syfy HD
13th Street HD
Sky Atlantic HD
National Geographic HD
Nat Geo Wild HD
Discovery HD
Sky Cinema Hits HD
Disney Cinemagic HD
Sky Cinema HD
All other Sky channels are also working fine. When i will play one of these channels, the popup with “Recording Live TV - Session” is showing up and in “Status” tab after a long time the “Live Session” is showing. But on the client (tested with Plex Web app and Plex iOS app) the channel is not running. It only shows a black screen with a endless spinner. The “live Session” in status tab disappears after couple of minutes. When i look into my OSCam WebIF, the channel are decrypted with OSCam. When i look into “Task-Manager” on my server, i see that the CPU capacity is getting high, so i think it is transcoding something and the ethernet port receives 10-13 MBits/s, so i think that the server becomes the stream from my VU+. But the ethernet port sends nothing out (maybe max 500 KBit/s, but it must be maybe 8 MBit/s because my server transcodes with 8 MBit/s. This will be displayed at least for other channels that work). So there goes no transcoded stream out.
I have try it with hardware transcoding enabled and disabled. But it don´t work.
When i try to record one of these channels, after couple seconds plex says there was an transcoding error.
I have contact the dev of HRTunerProxy at this thread. He says the plugin works. I think it too, because there are only a few channels not working.
Here are my logs. I hope these are the correct ones.
I started at 13:37 and close it after maybe 10 minutes manually. I have delete all lines before so that the logs are smaller and clearer.
com.plexapp.system.log (1.7 KB)
Plex Transcoder Statistics.2.log (3.6 KB)
Plex Transcoder Statistics.log (2.8 KB)
Plex Transcoder Statistics.1.log (203.6 KB)
Plex Media Server.log (2.0 MB)
Can someone help me or can a dev. maybe fix this issue? I am grateful for every advice.
Best regards,
el_malto
